Kenwood KSC-WA100 Car Subwoofer Logo
A
Anonymous Posted on Jul 30, 2012
Were can i fined power supply cord for ksc-wa100 kenwood subwoofer
1 Related Answer
Anonymous
  • 655 Answers
  • Posted on Apr 14, 2009
SOURCE: Where I can buy the wires for kenwood powered
Hello annieandstev,
The part number you want is E30-5462-38. It is available from: http://www.pacparts.com/. The cost is $43.66 plus shipping.
You may want to call their toll-free number and verify that the part is in stock: (800) 421-5080.
Hope this helps.
How to power supply of kCSWA900 Kenwood sub whooper power supply 10 pin
Take a look at this manual diagram. https://www.manualslib.com/manual/359815/Kenwood-Ksc-Sw10.html?page=5#manual
Given the above is not your model, at least it shows the 10 pin. Ironically, below I offer a diagram of your model. The irony comes in the fact that the diagram appears labeled in Japanese But if you compare the two diagrams, maybe something will make sense from the one with the English labels. Otherwise, you might fire off a query to Kenwood customer support. https://www.manualscenter.com/manuals/kenwood/kscsw900-owner-manual.html
Here is a 10 pin harness compatible with the subwoofer. Kenwood Subwoofer Amp KSC Wa100 Wa80 Sw10 10 Pin Harness for sale online ' eBay
I don't have any information on how to power supply a kCSWA900 Kenwood subwoofer. However, I can tell you that the Kenwood KSC-SW10 compact powered subwoofer has a built-in amplifier with a 38 watts RMS power and a wired remote for control over volume level, variable low-pass crossover (50-120 Hz), and selectable phase control (0°, 180°) . The subwoofer comes with a power/ground wiring harness and preamp (RCA) and speaker-level inputs .
How do i hook up my ksc-wa100to my stock stereo
if you are looking to just run the power solely through other speakers this will prolly not work you will still need to have power going to the amplifier.
Is this the only way to run this is in a car can I put in a home.
I have mine running in my room with just a small 12v - 8amp battery (dies quickly) but if you get a power converter for 120/220v - 12v with at least 12-15amps you could run in your home easily
1helpful
I just got a kenwood subwoofer KSC SW2000 with electric wires but has been cut. can you please provide me a picture or an installation manual if possible for proper connection. Thank you
Hello mikealtre,
Hopefully there's enough of the wires left to see their colors.
Here's a link to the manual. Other than the speaker level inputs, there's only 3 wires you need to be concerned with. Yellow is main power, black is ground, and blue is remote.
Hope this helps.
1helpful
2answers
Where I can buy the wires for kenwood powered subwoofer ksc-wa100? please help me I search and I don't find that.
Hello annieandstev,
Hope this helps.
14helpful
2answers
Ksc-wa100
Power wire
You should run a new power wire to the battery or fuse box from the Sub. For safety there should be a fuse on the cable at the battery or fusebox end.
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
