Question about Razor MX350 DIRT ROCKET - BLUE
Remove battery cover on razor mx 350
How to get cover off battery
Posted by littlemandoo on
  • littlemandoo
    littlemandoo Jul 31, 2012
    we have a razor mx 350 can't figure how to get battery out to check fuse or replace need help thanks
Jenny Theiss
    New Friend:
  • 53 Answers
The battery installation guide is available here
http://www.razorama.com/razor-installation-guides.html
It shows how to remove the covers.
Posted on Oct 25, 2013
Razor mx 350 powers on but doesn't run what is the cause of this?
Too many possibilities. Do a google search for "Razor mx 350 repair" or "repair electric bike"
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Oct 23, 2015 | Razor Cycling
The chain of my son razormx350 is runing backwards, how can I fix it?
Try connecting the red wire to the + battery post and the black to the - post.
Sep 26, 2015 | Razor Dirt Rocket MX 350 Electric...
My razor dune buggy won't drive
are you sure that the charger is putting out enough volts to charge the batteries? check the charger with a multimeter, then check the batteries with a multimeter, and viually inspect the batteries for bulging
Apr 28, 2012 | Razor Dune Runner 350 Go Cart
Philishave8890 when the razor states fully
It sounds like the battery pack needs replaced. You will find the correct battery type at shaveroutlet.com. See link below. You will need to order 2 batteries
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
To replace, you will need to remove the back cocer by removing the two screws. Take off back cover to access inside. For easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Sep 26, 2010 | Philips Health & Beauty
Batteries run down faster (Braun 7505)
You will find batteries at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
To open the shaver body, you will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out. Reassemble in reverse order
Jul 14, 2010 | Braun 7000 Series Foil and Cutterblock
Mx500 Razor Dirtbike battery issue
you could try charging it if this dont work you will have to replace it
Apr 02, 2010 | Razor MX500 Dirt Rocket
Rode mx 500 in light rain, stopped working. Batteries ok and LED
plz.we have to use a little common scense in this case.The razor-dirt rocket 500/or any model that run on _Electricity can not get "wet" for any reason.For example what happens when you drive a remote control car in water? The electrical motor dies,not before smoking first. It is nyeve of the manufacture to not a protective cover on or around the motor, which electricity flows inside. the 3 vent holes is for heat ventilation
Jun 20, 2009 | Razor MX500 Dirt Rocket
Razor MX350 DIRT ROCKET - BLUE Logo
146 people viewed this question
Top Razor Cycling Experts
Andrew Taylor
Andrew Taylor
ray gallant
STEVE yes that one
Are you a Razor Cycling Expert? Answer questions, earn points and help others
