IS THERE A RESET BUTTON, IF SO WHERE? TROUBLESHOOTING OR SOLUTIONS?
SOURCE: hit test/reset button now won't turn back on???
Test, reset sounds like a GFCI. is the machine draing properly? Sometimes the fan will blow , splash water and cause a ground fault. It wouldn't hurt to check the outlut and the breaker controlling it. Just plug a lamp in and make sure there is power.
Good luck.
SOURCE: alarm on on portable ac
If this is the kind I'm thinking of the condensate tank needs to be emptied of water.
SOURCE: Windchaser air conditioner alarm light is on and it won't turn on
look at the water shut of float, as when the bottom of unit fills with water nor the bottom water float shut of gets stuck in the up position of the toggle relay itself get falty this will cause the proble you discribe
SOURCE: Windchaser PACRWC-HP Portable Air Drainage Issue
obviously condensate sensor is fault. You may need to replace it. Yes it okey to turn it on now.
SOURCE: I need an exhaust hose
You and get flex duct at lowes 6" 25' to a box that should work the same, In the heating cooling section.
