SOURCE: Kenmore electric range: oven & broiler will not work.
All your oven features are controlled by the Electronic Range Control (ERC) board. This is your clock/timer assembly. Unfortunately, most do not have fuses and are not serviceable. You will probably need to replace the board. The following link explains how:
http://www.fixya.com/support/r3727366-replacing_control_kitchen_range
Replacement circuit boards can be purchased on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare. For the model number you have listed, the part number for a new board is 316207511.
NOTE: The overlay, which is the plastic template with the numbers and letters preprinted on it, does not come with the new board. It has to be purchased seperately. However, if the current overly is still in good shape, it can be peeled off the old circuit board and reused. The part number (if required) is 316220841.
If you have questions about this repair, please post back and let me know. I hope this helps you.
SOURCE: Tecnik TKC 1426 Kitchen range
Hi, switch off the mains for the cooker, wait for about 15 seconds, switch it on (0:00 flashing) then press the 2 buttons on the left at the same time and hold them, and then press the - or + button to set the time.
Cheers
SOURCE: clock,timer and oven does not work on Kenmore gas Range
I was turning the timer and clock knobs on my oven and now it won't work. I don't know what position they are supposed to be in ... any ideas?
SOURCE: New Electronic Oven Control does not work, Kenmore model 7909634
our top elementes work but the oven and the display don't . All fuses are good and nothing looks burnt. Some smoke came from inside the oven but the elements look good.What's wrong?
SOURCE: My Kenmore oven won't work there is a PF 5AB error
The PF on your control indicates a power failure and should be removed by pressing the cancel button. The 5ab code indicates the range is in the SABBATH mode.
If a power failure occurs when the SABBATH mode is set, the oven will return to the OFF mode and will turn the power OFF to the oven.
To ENABLE SABBATH mode:
* Open the oven door
* Press STOP/CLEAR
* Press both the HOUR "UP" and "DOWN" arrow pad at the same time - and hold for 5 seconds.
SAB ON will disappear from the display.
To disable SABBATH mode: Repeat the steps above and SAB OFF will appear.
To set the SABBATH mode for use during the SABBATH/Holidays:
* Press BAKE
* Pres TEMP "UP" and "DOWN" Arrow pad to enter a different temperature other than 350 degrees. (Between 170F and 500F)
* Press COOK TIME
* Press HOUR/MIN "up" or "down" arrow to set cook time
* Press DELAY START to set a delayed cook time (optional)
* Press and hold TIMER OFF for 5 seconds
SAB will appear on the display indicating it is ready.
* Press START
* To STOP cooking - press STOP/CLEAR
* To exit the SABBATH mode and return to normal operation - press and hold TIMER OFF for 5 seconds.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
