Could it be the circuit board?
Yes it sounds like the board. Make sure the opener is not in lock. If the light in the wall control is blinking press and hold the lock button for 3 seconds.
The wall light is not blinking. The motor will open and close the door when pressing the wall button but not remotes. When trying to program the new remotes, I do not get any signs of them connecting (light flashing on opener)
This is not the wireless entry keypad...I do not have one of those. I just noticed the keypad was tied into my question
SOURCE: Chamberlain Liftmaster Professional 1/2 HP
Okay...upon further inspection, my left spring has broken in two. Going to call around for some quotes to replace the spring. Thanks for the suggestions.
SOURCE: Liftmaster 1265LM 1/2 HP does not open or close with remotes
is chain moving. if not, gears are shot. if moving, is trolley connected.
SOURCE: Only Keyless entry or remotes can be programmed but not both
If you can program your remotes but when you program your keypad the remotes quit working and vice versa you have either the wrong keypad or it has reverted to an earlier technology. Make sure the keypad is for your specific model door opener.
SOURCE: Liftmaster Keypad problem
First thing to do is make sure it has a good battery installed. If this doesn't take care of the problem then the keypad is going bad and needs to be replaced. It is important that you get the same keypad as there are others out there that look the same but will not work.
