I have original DC07, can't access belt without getting into motor assembly
Click the link below for full instructions how to change belt on dc07
http://www.youtube.com/watch?v=C83DeJtY6lA
SOURCE: dyson dc07 motor sparks
Hi.
I think you are looking at replacing the motor with a new one.
http://dysonmanuals.llc.nu/
Chris..
SOURCE: dyson DC07
First, check your outlet for power...plug something else in. Then, inspect the cord and check the power switch. You can use a multimeter to test across the power plug of the vacuum in the ohms position. Turn the switch off and on. If it does not change readings...the switch or cord is bad. If it does, it might be the motor.
SOURCE: Dyson DC07 motor does not come on. Hoses are
depending on where you take the unit. the motor is about $60 or $70, shop time at a vac shop is going to be about $40 to $50. The whole thing will run you about $150. you can go to the Dyson web site and find a service center.
SOURCE: I am trying to find a Manual for my dyson dc07 to
You can view the manual here:
Dyson DC07 Manual
SOURCE: Sparking motor on Dyson assume motor brushes at fault?
A replacement motor can be purchased direct from Dyson via our Helpline on 0800 298 0298 at a cost of £36.31.
Alternatively we can arrange a service for £69 which includes parts, labour and VAT. This can also be arranged via our Helpline.
Kind regards
Darran
Dyson Customer Service
