Are the fuses okay? With the ignition switch off, you could hook up a temporary wire from the chassis of the car (the outside metal part of a cigarette lighter is a good ground) to the backside of the radio. Once secured, you can try the stereo again.
Any bolt that connects to the metal would be good. I simple test light can be used to check for a good ground. If none are close, simply make your own with a self tapper screw and ring terminal. Most of the grounds are located around the steering column area.
