Question about ASUS Computers & Internet
Computer beeps every 30 seconds
My computer started beeping suddenly. It happens every 30 seconds or so. It sounds like cars breaks or something like that, really high pitch. I checked temperatures with Speccy and Core Temp but everything is normal. My bios speaker is even broken so it can't be making the beep. I don't even know where it comes from :C
  • ASUS Master
  • 5,660 Answers
It is car brakes. Turn that game off.
OH, I'M JUST KIDDING!
BIOS speaker is broken, and you hear high pitched beeps?
Hmmmmm,..........
CPU temperature in normal............
What is the CPU, and what is the temp? Hey, I gotta know so we are on the same page here, lol!
Me?
Those repeated high pitch BIOS Beep Codes indicate a CPU problem.
I would remove the Heatsink/Fan combo, and replace the Thermal Paste.
(Following Anti-Static Precautions, and cleaning the CPU, and Heatsink, of course)
Also make sure the Heatsink is sitting flat.
Yes, I know what you stated about Speecy, and Core Temp, but I would try it anyway.
Still no?
CPU is sounding Taps, and telling you goodbye.
Regards,
joecoolvette
Posted on Jul 30, 2012
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 40 Answers
SOURCE: Computer Fails To Switch On
If you still have *********** board manual it will tell you how to reset your bios by removing the battert from your motherboard and its normally a jumper you have to move for 30 secs.
Hope that helps you
Posted on Sep 15, 2008
mbase213
Mark Taylor
  • 728 Answers
SOURCE: A short beep every second coming through the
Hi royjack74,
a repeated beep is a memory issue. First check for improperly seated or missing memory.
Good Luck
Mark
Posted on Dec 13, 2009
Anonymous
  • 13 Answers
SOURCE: I HAVE A ABIT FATAL1TY AA8XE MOTHERBOARD AND ITS BEEPING @ START
reset the cmos jumper and re program it
Posted on Jan 24, 2010
High pitch droning sound
There is a metal tab on some pads that contacts the rotor to make hideous noises telling the driver they need to replace the brake pads. It's in your owner's manual.
May 05, 2015 | Cars & Trucks
Wont start up and high pitch beep
The beeping is from the motherboard most likely. Sounds like you have some kind of virus. You may be able to access safe mode by holding alt+f4 when start-up but other then that I would take your PC in to get checked out.
Mar 20, 2015 | Computers & Internet
2011 Nissan Altima .. High pitched beeping for 3 seconds when starting the car or turning the car off
Sounds like your alarm system. If you know how reset it or unplug it and plug it back in see if that helps or you can always just leave it unplugged. That should stop the beeping.
Jul 07, 2014 | Cars & Trucks
My rca tv has a distorted picture and a really high pitched buzzing sound
Problem is in High voltage circuit and likely either the high voltage transformer or a connection right under or around it.
Jun 16, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
High pitch winding noise on cold start up.
Sounds like a constricted IAC Idle air control valve passsage. Fairly simple to fix. Remove air filter trunking all the way to the throttle body to allow access. The IAC allows air passed the throttle when closed at idle. Just on the inside of the throttle body in front of the throttle flap there is an opening in the throttle wall. This is the air inlet to the IAC; there is an outlet similar on the other side of the throttle. Use carb cleaner and cloth to shift the grime from this tubing and get it like new. Hold the throttle flap open to get at both ends of the IAC tubing. The IAC can be detached and cleaned to a shine. Reinstall the IAC and replace all air pipe ducting. Leave for about 20 minutes to allow any cleaner residue to dry out. When you restart you might experience a bit of uneven running but this will disappear very quickly as the last of the cleaner dries out
May 04, 2010 | 2004 Chevrolet TrailBlazer
My Braun 7570 has suddenly stopped working, but there is a high pitched whine when I switch it on.
This sounds like a battery problem. The likely remedy is to replace them. You will find batteries for your shaver at shaveroutlet.com
Jan 17, 2010 | Braun Syncro 7570 Electric Shaver
30 Seconds High Beeps with Hazzars
The battery is low which is causing the alarm to activate, replace the battery. I'm going to guess that it gets pretty hot where you are between the times you listed. BMW cars have been known to be affected by heat.
Dec 17, 2008 | 2001 BMW 5 Series
High pitched car sounds
does the noise and light occour at the same time ? another cause of a high pitched noise can be slipping drive belts, alternator,powersteering etc so check them for tightness, condition etc, does the noise happen when car staionary and just rev the engine ? if so i would say it is the drive belt/s, go back to the VW dealer re the ABS light and get them to check the OBD as should be done as part of the service , hope this helps
Mar 29, 2017 | 2001 Volkswagen Jetta TDI
Loud humming or high pitch buzzing noise coming from my rca dlp tv 50 inch
I have a very high pitched sound and when I move the tv it will stop for a second or two and then start again. The sound sometimes stops all together. But very high pitch sound.
Aug 08, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
Computers & Internet Logo
614 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
