Teac Legacy DR-L700 DVD Player Logo
A
Anonymous Posted on Jul 29, 2012
Teac dr-l700 manual - Teac Legacy DR-L700 DVD Player
1 Related Answer
Anonymous
  • Posted on Feb 04, 2008
SOURCE: multiregion for teac DR-L700?
Did you see this? http://www.avforums.com/forums/archive/index.php/t-149200.html
dom
Flashing Power Light
your surround sound system seem like having dry solder joint at PCB . one thing you can do is to open up the back cover first looks for dry solder joint ( if you can find ).if not just re-solder those solder looks very thin.it may help.
2answers
Teac DVD L700 Power Supply
The only thing I can tell you is to check the cable if its plugged in correctly... wierd! might be electricity problem to where you moved it. Did you hit it while you were moving it?
Hello, I am the owner of a Teac DVD Receiver DLR 700 and associated 3 channel amp A-L-700P. I have been trying (unsuccessfully) to play mp3 cd's on the appliance. I use it for music and radio...
I know that this sounds obcious but you need to connect the audio leads (L and R) from the player to the amp as well as the control connecter before you connect the speaker cables from the amp. Otherwise just connect the speakers direct to the player.
Is the Teac RW-H300 a unit that can be repaired easily?
It would depend on a zillion things. Only a hands-on technician could answer it. Diagnosis and Labor costs can be open-ended.
Typically, modern electronics is not economically repairable. At $355 on Amazon for a new one, it could easily be cheaper to replace than repair.
http://www.amazon.com/Teac-DR-H300-TEAC-DVD-Receiver/dp/B000PX91GG
When I turn it on I get "System Err 50 please pwr off" how do I fix it.
Hi this is the only solution for your query jut do that
i) If these error occur, turn the DR-1 power OFF and restart the unit. If the error message continues to appear, contact a TEAC Repair Center
other than that no solution we have so far.
1helpful
My Teac DR-H300 will not open the dvd drawer anymore. It looks like the magnet won't release on the drawer. Can anyone tip me what to do?
I solved this by holding the power button down for 5-10 seconds. After a reset the drawer opened as normal.
2answers
TEAC DH 300 can't get HDMI to work, something to do with " all" settings.
I have the same problem. I have connected it to Philips TV, but there is no signal. I cannot even enter setup on Teac. The SETUP button is not simply working. Can anybody help? Please!
Top Teac Televison & Video Experts
deton8 von Splosion
Paul Katynski
Paul Katynski
Are you a Teac Televison and Video Expert? Answer questions, earn points and help others
