Question about Furniture
What are the best speakers for a media center?
Posted by phil on
Charisse Waller
The best quality speakers in 2019 is the GoldenEar Technology Triton Five. It is a world-class speaker which has an impressive lowest price-to-performance ratio. It has an incredibly clean look and is a perfect fit for an audio enthusiast looking for excellent sound quality. It gives the highest possible sound quality at a reasonable price. The speakers come in a pair of floor-standing loudspeakers with sleek black covers. What provides the Triton Five an edge over its competitors is the superior sound quality in a fraction of price when compared to other loudspeakers. It gives the right amount of oomph when listening to funk, hip-hop and other bass-driven styles of music. Check out AudioStance to know more about the best quality speakers.
Posted on Nov 04, 2019
neort
    New Friend:
  • 30 Answers
The best, and the most expensive speakers thereis are the Boss speaker sound series. Boss is considered to be the bestproducer of speakers for years, they also got the satellite speakers editionwhich are very small and elegant and produces a rich, quality deep sound andfits the living room perfectly.
Posted on Jul 29, 2012
Windows media player won't play any audio selections , says can't find files
Windows Media Center is the home entertainment hub on a Windows computer.
With Media Center, you can play live television, songs, DVDs and slideshows.
It is preinstalled on Windows XP Media Center Edition, Windows Vista Home Premium/Ultimate Edition and Windows 7 Home Premium, Professional, Enterprise and Ultimate editions.
From time to time, users run into issues trying to play audio or video files, or with an extender connected to Media Center.
Extenders are devices that allow you to "extend" the Media Center onto a TV screen or larger display. The Xbox 360 gaming console is an example of an extender.
Launch Windows Media Center from your computer's Start menu.
Scroll down to "Music" on the Media Center home screen.
Select "Music library."
If you find an empty folder under "Music Library," navigate to the folder on your hard drive that stores your music file and add it to Media Center's library.
If the problem isn't an empty folder, look at the file extension on the music file that won't play. Media Center can't play files with unknown or incompatible extensions.
If you find a questionable extension, skip that file. Click once on another file with a different extension, one you know is compatible with Media Center, and then click "Open" to test if you can play that one.
Media Center will play MP3, CDA, WAV and other music file formats.
Open Windows Media Player from the Start menu if you receive a codec error while trying to play either audio or video files.
If you open the file in Media Player, the codec will download automatically.
You should then be able to play the file in Media Center.
Troubleshoot your firewall settings if a Media Center extender doesn't work.
You'll have a problem using an extender if Windows Firewall blocks it.
Go to "Control Panel" from the Start menu and double-click on "Windows Firewall."
Click on "Allow a program or feature through Windows Firewall." Click to check "Media Center Extenders." Click on "Apply."
Check external speaker cables to make sure they're connected if you can't hear any sound. Check the computer's volume settings by clicking on the "VOL+" icon at the bottom right corner of the main Media Center screen to make sure the volume is not turned off or down too low.
You may need to reconfigure your speakers if you're having volume or sound issues.
Scroll down to "Tasks" in the Media Center home screen and select "Settings."
Click on "General" and select "Windows Media Center Setup." Click on "Set Up Your Speakers." Follow the on-screen prompts to reconfigure your speakers.
and you should run the chkdsk utilty
You could run the chkdsk disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive
or an easier way i have found to run the chkdsk utility
click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
have no input while the chkdsk utility is in progress any input may further damage your computers operating system and hard drive.
hope this helps
Oct 23, 2012 | Toshiba Satellite A60-692...
I cannot get sound from Insignia Speaker ND-POS20?
Speaker Placement Before shopping for speakers, try to imagine where you're going to put them in your room. Speakers can be placed on floor stands, hung on wall brackets, or placed on furniture. Subwoofers typically sound best in room corners or near the left- or right-front speakers.
The front three--left, center, and right--speakers usually sound best when positioned with their tweeters elevated to the same height as a seated listener's ears. In any case, try to keep the center speaker near the same height as the left and right speakers.
You can place speakers on shelves or on/in a low cabinet or entertainment center. Some speakers are better suited to this arrangement than others. "Acoustic suspension" sealed satellites are the most appropriate. Next best are ported speakers--as long as the ports are located on the front of the cabinet. However, speakers with rear-mounted ports won't perform at their peak when placed inside a piece of furniture.
As for the rear-channel surround speakers, they usually sound best when positioned three or more feet higher than the front speakers. However, high-fidelity DVD-Audio and Super Audio CD music will sound best when surround speakers are placed at the same height (ear level) as the front speakers.
Read more: http://reviews.cnet.com/speakers-speaker-systems/insignia-2-0-speaker/4505-6467_7-32912127.html#ixzz1MpaHsur1
May 19, 2011 | Insignia 2.0 Speaker System (2-Piece)
HP Media Center m7250n - How to hear audio steamefrom panel input
You need to unmute the line-in and adjust its level as necessary. Usually you can just double click on the speaker icon in the system tray and the Line In is by default muted and it is on the far right column (depending on your setup). If it is not displayed, click on Options and Properties and put a check mark by Line-in so that it will display.
Feb 11, 2010 | HP Media Center m7250n (ED842AA) PC...
Speakers Dont work
It might be that ur drivers are bad or maybe ur speakers are shot n the best way is to try n connect the speakers to a different sound source... anyhow as for your codec issue the best bet is a codec pack called Klite... it is the best n plays anything n everything... you can get it here...
http://www.free-codecs.com/K_lite_codec_pack_download.htm
Download the full version n post if it worked...
Feb 14, 2009 | ZT Group CISNET A7050 PC Desktop
Want to test to see if bose lifestyle 18 works.
Hi sorry but what do you mean that you have lifestyle 18 system? The lifestyle 18 system consist of the media center/DVD player, the bass module, the satellite speakers and the RF remote control (aside from tons of cables)
If you have the media center/DVD only, then you require the power adaptor. you can test if the media center is functioning if the LCD display is working. you can also connect an external powered speaker or an amplifier fro mteh AUX out behind the media center.
Do note that doing so will only give you limited control of the system since you require the whole lot to make everything work properly.
Glad to be of service.
Jan 27, 2009 | Bose Lifestyle 18 System
Additional speakers for 321 system
No. You would need some kind of audio out connections on the back of the media center. The only audio outs it has are the
Acoustimass® Module – SPDIF connector.
Unless you were to hook up an amp before the Bose media center. In other words, you could run your TV to another amp's line in. You would hook up additional speakers to this other amp, then run audio line outs to the line in of your Bose media center. Some stereo amps have a line out or record/tape out, it is from here that you would run the cables to your Bose media center line ins. The disadvantage to doing it this way is you would have to plug all your media devices (dvd, tv, etc) into this amp first and your Bose remote wouldn't let you switch between devices. If your media devices you have offer digital audio, then you would want an amp that also offers a digital out for the best sound. Otherwise you will end up with analog out from this amp to the Bose media center and thus lose any of the digital signal information like surround information. So there isn't much point in doing this. If your gonna get an amp that has all the digital in's and out's, you might as well just use it with new speakers and forget the Bose system you have.
Jun 06, 2008 | Bose (321GS) System
Av3 2 1GS Media center
Yes, Try Media Receive Ltd - 0845 20 20 118
Dec 14, 2007 | Bose 3·2·1 GS II System
Sound cuts out on one speaker
Are you able to get sound on the speakers without the media center? In case if the problem is just not limited to media center-Then it could be a sound driver issue...!
In case if the sound works fine outside the media center then its a setting problem with the media center.i suggest you run the first run wizard to reset the media center.
To reset the media center
1)Navigate to
C:\Documents and Settings\All Users\Application Data\Microsoft\eHome
locate the file- ehshell.config-Just right click and delete it
2) delete the following registry keys
open registry editor
Start > Run > type regedit and hit enter
it opens a registry editor window
locate the following keys
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Media Center\Settings
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Media Center\Settings
right click on these keys and delete them..You just have to dig down to these keys and delete them in the left hand pane. and then close the registry editor and restart the system.
After the reboot windows will ask you to reconfigure the media center-you just have to follow the wizard to complete the process...This should do the trick and should avoid a complete reinstallation of windows.
Good Luck.
Nov 01, 2007 | Microsoft Windows XP Media Center Edition...
Furniture Logo
177 people viewed this question
Top Furniture Experts
Tom Chichester
ray gallant
Are you a Furniture Expert? Answer questions, earn points and help others
