Question about Radio Shack Wireless Weather Forecaster
My 63-1090 registers everything correctly but has no outside temperature or humidity. I have tried all three channels.
I enjoyed my 63-1090 when first received it as a give, but after few weeks, it stopped registering the outside humidity and the outside temperature--everything else works fine. I have reset. I have tried all three channels. Nothing appears in those two boxes. How do I get it to work?
Posted by Donna on
  • Donna Jul 31, 2012
    I have brought the sensor to sit on the same surface as the thermometer. I have changed the batteries in both units; then reset both units. Nothing still registers in outside temp or humidity boxes. The boxes for the inside temp and humidity work fine as does the clock at the bottom of the unit. Nothing I see to do allows for registering the outside temp and humidity. I have the manual for the unit. Itn it yet says for the red light to blink every 40 seconds as it recalculates the outside factors. The sensor does this, but there does not seem to be a connection between the sensor and the thermometer.Thanks for your suggestions.
1 Related Answer
DaGeekyWon
  • 6 Answers
SOURCE: my scanner will not transmit digital trunking channels
I have the same problem. A good shake restores the digital channels to working order for a few hours again.
I think I have a cold solder joint or similar internal problem. I've only had it a few months.
Since a quick shake cures it, I'm not going to return it yet. But it could be that there is something going on with the internals.
Posted on Jan 05, 2013
I have an Essics H12-400 humidifier that appears to be operating correctly but it doesn't need refilling but every 4 days or so even on the highest humidifying setting. It has a new filter.
It may very well be operating properly. One way to tell is to buy an inexpensive humidity gauge and check to see what the humidity level in the room is. (You rarely need extra humidity when the outside temperature is above 32°, and usually not until it drops into teh teens.)
Here's one you can pick up for $10 on Amazon.
Dec 07, 2017 | Humidifiers
How do you use it
--- SCANNED INSTRUCTIONS ---
CLOCK AND DATE SETTING: 1. Press and hold MODE button for three seconds. The minutes display will begin flashing. Press MODE button to switch among minutes, hour, 12/24 hour, month and day. 2. Press ADJ button to set value of the minutes, hour, 12/24 hour, month and day. NOTE: Original screen will return after one minute of inactivity. To view the date, press ADJ button.
ALARM CLOCK SETTING: 1. Short press MODE button to switch from clock to alarm clock. 2. Press the ADJ button once to make the D))))) symbol appear, which will indicate that the alarm is on. Press ADJ button again and a bell symbol will appear, indicating hour notification signal is on. The hour notification signal
sounds once at the top of every hour. Press ADJ button again to activate alarm clock and hour notification signal, press ADJ button again to clear all.
MEMORY FUNCTION: 1. Press the MEMORY button for maximum temperature and humidity to display. Press MEMORY button again for minimum temperature and humidity to display. Press MEMORY button again to return to current temperature and humidity. 2. Press and hold MEMORY button for three seconds to clear maximum temperature, minimum temperature and relative humidity.
COMFORT DISPLAY: When temperature remains between 68F to 82F (20C to 28C) and the relative humidity remains between 50% and 70% "COMFORT" will be displayed. When relative humidity is above 70% "WET" will be displayed. When relative humidity is below 50% "DRY" will be displayed.
FAHRENHEIT/CELSIUS: To switch between Fahrenheit and Celsius, press FAHRENHEIT/CELSIUS SELECTOR button on back of unit.
INSTALLATION: 1. Use provided suction cups to position the sensor probes in the terrarium. 2. Position THERMOMETER & HYGROMETER in desired location outside of terrarium with a built-in stand.
BATTERY TYPE: 1 PC Button cell (AG13/LR44)
WARNING: Install THERMOMETER & HYGROMETER and sensor probe out of reach of pets and away from water.
For more information about All Living Things products, please call 1-800-806-7870.
Dec 24, 2013 | ALL LIVING THINGS Digital Thermometer &...
How should wine be stored?
There are three crucial elements to consider when storing wine - temperature, humidity and light & vibrations.
Temperature - it is best to store wines between 50-57F
Humidity - try to achieve a level of 60% humidity; which helps to keep the cork moist
Light & Vibration - keep your wines away from direct light and very still so not to disturb the elements inside the bottle
Feb 03, 2013 | Wine & Spirits
What is the gallons per 24hour output capacity of this unit?
There are several variables that will determine the gallons used per 24 hour period.
  • At what humidity level do you have it set for? The higher the level, the faster consumption.
  • How much air movement is there in the are in the house/area of the humidifier?
  • How air tight is your home?.
  • How may people occupy the home?
  • Whats the temperature setting for your primary heat source?
Let's assume that everything is perfect. Your humidifier holds approximately 6 gallons of water, when completely full. The ideal humidity level depending on the outside air temperature is 40 to 50%. Once the humidity level you have it set for is reached, the humidifier shuts off. When the humidity level drops significantly, it turns back on. So, as you can see, it's difficult to come up with an exact figure. But based on if everything was perfect, about 1.5 to 2 quarts per hour or almost 6 gallons in 24 hours.
For more details on this humidifier call 1-800-546-5637.
Hope this helps you.
Rich
Feb 09, 2011 | Holmes Products Cool Mist HM3500...
My new storm tracker STX7500 weathertech does not display the outside temperature
Take out the batteries in the main station for at least 5 min. Also, check the batteries on your outside station and make sure that they are new and the same brand, not rechargeables. Make sure that the outside station is reading a temperature and humidity first. Make sure that the outside gauge is close enough to your inside station. Having your inside station to near electrical or metal things or the outside station too far from the inside station is the most likely of your problems. To test this, once you've restarted your inside station, bring it close to the outside station and see if it's reading. Also, check the bottom right to see if your inside station has an antenna icon. If so, it's just updating from the radio station that updates your station often. Wait for that antenna to disappear from the bottom screen before trying to figure if your outside station is reading correctly. Finally, make sure that you have the right time zone, state, and city programmed into your inside station. If none of these work, call or e-mail the link in your book. Hope this works.
Dec 28, 2009 | Discovery Channel Toys
Outside unit not registering temp and humidity to base unit
Uniden EWCI936
To get the outside temperature working again, open the outdoor sensor box carefully loosening the one screw with a screwdriver, insert 3 brand new AA batteries, check phone for outside temperature. If not showing on the phone display, try changing the 'channel' setting, just above the batteries. Be careful not to break the tiny switch. Gently use a smaller flathead screwdriver, if needed. There are 3 settings. Mine worked fine on the first setting. If it is showing on the phone set screens, then, carefully screw the lid back on to the sensor box, and re-insert into the sensor wall holder. I keep mine in a plastic bag on a shelf outside, away from sun, so I can get a true reading day or night. It is always a bit warmer in the sunlight than the true outdoor air temperature. Enjoy
Apr 24, 2009 | Lands Phones
Shift 3 projection alarm clock cannot connect with the remote
Did you put two AAA batteries in the remote? Use a small phillips to take the cover off of it. Then hold channel on the main unit for three seconds to synch it with the remote.
Mar 14, 2009 | La Crosse Projection Alarm Clock with...
GDM-26 humidity very high
assuming fridge is at correct temp, i suspect fault is with your humidity detector. the humidity inside a fridge is a lot less than the outside air
Oct 09, 2008 | True GDM-26 Refrigerator
Radio Shack Wireless Weather Forecaster Logo
190 people viewed this question
Top Radio Shack Measuring Tools & Sensors Experts
Harrie
Are you a Radio Shack Measuring Tool and Sensor Expert? Answer questions, earn points and help others
