could be the cotton is too old ( cotton has an additive in it to stop it unraveling and this additive deteriorates with age and weakens the cotton--makes it rough and so it will not slide easily through the eye )
go up an needle eye size
check that the thread is not jamming rather than between he tension plates
check that you have the needle in correctly ( groove in the needle facing the thread )
well, Rose, i could make a few suggestions- but, my wife is the guru of sewing machines- will turn her loose on it later- what make & model? sounds heavy duty. later.
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
The needle thread breaks
7. The thread is either to heavy or to fine for the needle 8. try a different thead 9. try adjusting the top thread tension
7. The thread is either to heavy or to fine for the needle 8. try a different thread 9. try adjusting the top thread tension--to a lesser number or letter use your manual to guide you through tension adjusting
has the cotton wound too tight on the spool when you filled it?
have you put the spool in the right way up or in, try turning it over to catch the thread in the groove the other way round....the spool should have it's thread pointing left to pull back into the groove. hope that makes sense. if not can draw it and email it
its not put round the machine quiet right like its twisted or looped over some thing or the tenshion is to tight? even the cotton reel could be to tight? you will need to forgive me,, on this,,, im just a man who cant sow a button on?
Make sure you have a new sharp needle installed for both problems and sometimes you need a particular kind of needle for the fabric. Also some machines don't deal well with 100% cotton thread. For some reason it gets caught up in the machine somewhere and breaks. Gutterman and Metrosene make excellent although slightly more expensive threads. Coats and Clark thread is good too. They make an all cotton thread but it doesn't come in as many colors. If you have the old spools of cotton thread from Walmart, just use them for topstitching if you need the color. Other wise, use them for hand stitching or throw them away. One more thing that I can think of off hand, one of my machines does not like lining fabric. For some reason the thread breaks if I stitch really fast. If you have to use that thread, you may try sewing slowly. One more thing, when was the last time your machine was serviced? This can make a huge difference if it's been awhile and you use the machine a lot. Good luck. Hope any of this helps.
