The typewriter has been stored for years without use. When first turned on it would not operate at all.I can get the tabs to work and carriage return to work. It will let you type any 'One' letter then no more. To type another letter you have to re-power it.
SOURCE: IBM Wheelwriter 5--Carriage advance problem
Try code (lang) key either the X or L depending on when it was made
DickyO
SOURCE: Carriage return problem
If it returns with the express key the latching mech. on the rt. side is probably gummy. Take off the case, get some WD40 and spray the mechinism that latches the ret on the rt. side below the platen.
DickyO
SOURCE: typing wrong letters on Brother SX-4000
Try hitting [CODE] + [RESET] at the same time to reset the cartridge. Make sure the cassette is installed correctly.. the "ear" on the cassette should always be on the upper right.
