Question about Panasonic KX-TGA560M 5.8 GHz Cordless Expansion Handset
How to deregister panasonic phone handset tga560m
5 Related Answers
Anonymous
  • 944 Answers
SOURCE: Hard reset of KX-TCD580 Base
Go to this link; http://panasonic.co.uk/customer-Support/download-centre.asp and input "KXTCD580" in the search box - after a few disclaimer screens you get to the manual for your phone. page 29 details reset for the handset Page 32 details base unit reset Page 48/49 details cancelling handsets to the base Hope this helps, please post again if you are still having problems with your phone :)
Posted on Apr 01, 2007
Beni S-P
arben pllana
  • 1006 Answers
SOURCE: PEOPLE CANT HEAR ME OTHER END
The microphone in handset is broken!
Posted on Nov 16, 2007
try2help
SOURCE: DeRegistering a Damaged Cordless Phone????!!!!
If you are still looking for an answer on dereg of a handset, the manual says Menu - 0-0-2 then 3-3-5-OK then select the handset you want to cancel/deregister
Posted on Feb 17, 2008
Anonymous
  • 9 Answers
SOURCE: sync a new handset to kx-tg5632 phone
This works on MY panasonic; May work on yours too!
Registering a handset
The included handset and base unit are
preregistered. If for some reason the
handset is not registered to the base
unit, register the handset.
1 Handset:
{MENU} i {0}{0}{1}
2 Base unit:
Press and hold {LOCATOR/
INTERCOM} until the IN USE
indicator flashes.
LAfter the IN USE indicator starts
flashing, the rest of the procedure
must be completed within 1
minute.
3 Handset:
Press {OK}, then wait until a beep
sounds.
4 {OFF}
Registering an additional handset
See page 5 for information on the
available model.
Start from step 2.
Posted on Jan 01, 2009
Anonymous
SOURCE: DeRegistering a Damaged Cordless Phone???!!!!
Here is the procedure as given to me by Panasonic Tech Support.
To DEREGISTER, using the handset you want to register, push MENU.....002.......335...and hit ok.
Then press the handset number you want to deregister (1 through 4). Don't worry if the handset says there is no link to base. This is because you just unregistered it so there will be no link.
To REGISTER, press and hold the locator button on the base unit until the green LED starts blinking. Then take the handset unit and press MENU.......001 and hit ok. Your unit should now be registered.
Posted on Feb 16, 2009
How can I get the code to retrieve messages from a Panasonic KX-TGA560M?
The KX-TGA560 isn't an answering machine. If you have a separate answering machine connected to your phone line, please consult its documentation. If you're subscribed to a voicemail system provided by your telephone company, please contact your telephone company for instructions on accessing their voicemail system.
Jun 12, 2012 | Panasonic KX-TGA560M 5.8 GHz Cordless...
Hot do you fix Panasonic KX-TGA560M 5.8 GHz Cordless that has nothing displaying on the screen?
Cannot hear from handset or earphone, can only hear from speaker phone. What can be the problem.
Aug 24, 2010 | Panasonic KX-TGA560M 5.8 GHz Cordless...
Caller id
the digital answer machine did not torn on? Why?
Feb 05, 2008 | Panasonic KX-TGA560M 5.8 GHz Cordless...
Nov 05, 2007 | Panasonic KX-TG6074B Phone
I have a Panasonic KX-TG6700 base unit and KX-TGA670B handsets. We had a similar problem where we were no longer able to deregister the handset using the handset itself. We wanted to be able to use that slot that the broken phone was still occupyng. The solution that we found in the manual online was to hold down the intercom button for 3 seconds until the "in use" light turned on. Then press and hold the number of the extension you want to deregister until it beeps. At this point the base unit has freed that extension.
Nov 05, 2007 | Panasonic KX-TGA600B Cordless Expansion...
Panasonic KX-TGA560M 5.8 GHz Cordless Expansion Handset Logo
111 people viewed this question
Top Panasonic Lands Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Henk de Ruiter
Henk de Ruiter
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
