Ok, so my phone seems to have stopped charging completely. I'll plug it in and the charging indicator comes up for a few seconds and then it gives me a "Check Battery" alert and the phone stops charging. I tried charging the phone while it is off and I get the same result. It has gotten to the point where the phone won't even recognize the charge. Needless to say the phone died and I can't get it to indicate that it's charging or even give me the alert again. I'm not sure if it is the actual battery, an issue with my charger, or the software in the phone? Any suggestions would be appreciated, thanks
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
SOURCE: Charge complete
I wiped the inside where the charger goes with windex. It's working fine now.
SOURCE: the phone powers on & when charging, it will
I suggest you remove your battery and place it in another similar phone and with your charger to see if i will give the same problem.
If it did not give the same problem, it means the charging port of your phone is bad and will need to be replaced.
But i advice you test each component am going to mention now one after the other because it may also be that any one or both are bad.
Check your charger, try use it to charge another similar phone, if it charges,it means the charger is still good.
Try your battery as well in another phone and if it will charge, if it does, then it is your charging port that is the problem.
Take care.
