Question about Dacor Ovens
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
Dacor Epicure Oven 30" double oven (electric) with convection bake for top and bottom ovens. Ten years old at least. Tried the reset button already but did not fix the problem, What should I do?
Posted by Michele Gee on
daniel hendrickson
    President:
  • Dacor Master
  • 1,922 Answers
It could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Posted on Jul 29, 2012
2 Related Answers
kachbibi1
Bill Dickerson
  • 979 Answers
SOURCE: Heating element on upper oven of a wall Thermador Oven
The control switch may be bad on it. If there are 2 elements on the top, they both are not bad at the same time.Check to see if the wires have not burned off the control switch first. Check to see if your breakers are O.K. Turn them both(maybe 3) off and then reset.
Posted on Jan 30, 2009
David Shaub
  • 2976 Answers
SOURCE: oven won't heat
Check your main panel. If you ran it for a long time with the door open, the elements never reached their shutoff temperature. Quite possibly, you burned them out.
Posted on Feb 19, 2009
What is a error code F/19 mean?
That error means that the lower oven is not heating fast enough. IT should rise to over 150 in 5 minutes. Check the broiler and the baking coils for continuity. If they are ok then check the radiant heater in the convection fan housing.
May 12, 2015 | LG 30" Built-In Double Electric Convection...
Frigidaire double convection wall ovens, model GLEB30T9DSA ... The top oven will not heat, both the bottom element and the broiler.....
I have the Frigidaire PLEB30S8CCA single wall oven. About 3 months ago the baking element appeared to have gone out. We replaced it, but still didn't work. We ended up sending our control board off to a company named Corecentric. They fixed the problem and returned it to us. The oven has worked perfectly ever since. I searched extensively for a new one, but no one sold them anymore. I found Corecentric on Ebay. They were able to confirm over the phone that it was more than likely a control board issue. It cost about $130. My husband was able to do it himself by taking a couple before px and using them when reassembling it.
Apr 04, 2014 | Frigidaire 30 in. Electric Gallery Series...
Bosch double electric convection oven: top oven will heat and display code E1 15 once it gets to 350 degrees, will continue to heat with no response to temperature choosen. Set oven to 350 degrees and...
replace the oven temp sensor, it looks like a metal rod sticking out from the inside back wall inside the oven. part here....
http://www.repairclinic.com/PartDetail/Oven-Sensor/650101/1557889
Jan 23, 2018 | Bosch HBL3420UC Electric Single Oven
My oven doesn't heat up
It could be the switch or heating element
Mar 17, 2013 | Thermador SM272 Electric Double Oven
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
Oven won't heat past 200 degrees
Unplug the range.
Remove the oven racks.
Remove the screws on the bake element.
Carefully pull the bake element out.
Remove the wires from the element.
Use a volt meter set for ohms/continuity and touch one meter lead to one element terminal and the other lead to the other element terminal.
No reading is a bad element/
If you get a reading your oven control is bad.
Jul 24, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Thermador over/microwave/heating drawer model SMW272YP Bake bottom element will not heat up. I have replaced the element. The display pannel has been replaced in the past, but still keep having the same...
I just found out my baking oven doesn't work and I hear the fan for the convection roast, but no heat. I had the appliance man out and he said that I need a relay board! Big bucks and they don't make this model anymore. Moreover, the microwave and warming drawer work fine. This is ridiculous!
Mar 07, 2009 | Thermador C302U Electric Double Oven
Oven will not heat - Thermador SMW272 Electric Oven
since you said the broiler does work , take the wires off the broiler element and put on the bake . then when you put on the broiler the bake should work . the light bulb principle, just remember to wrap all loose wire with electrical tape and disconnect from wall while working.
Dec 12, 2008 | Thermador SMW272 Electric Double Oven
Oven does not Bake, Heat Up
Replace the oven glow bar igniter. If you post an exact model number (located on sticker behind lower drawer) I can give you a part number.
Sep 02, 2008 | GE JGRP17 Gas Single Oven
Ovens Logo
740 people viewed this question
Top Dacor Ovens Experts
Paul Bade
Vincent G
Vincent G
ray gallant
Are you a Dacor Oven Expert? Answer questions, earn points and help others
