Question about Fagor 3FCA-68NFX Stainless Steel Refrigerator
My fagor runs but is not cold - Fagor 3FCA-68NFX Stainless Steel Refrigerator
Posted by stepina_l on
I need some help on how to start Fagor refrigerator
Fagor Refrigerator manuals
Which Fagor model is it?
The link above is for free manuals for many Fagor models.
Feb 19, 2018 | Fagor Dishwashers
I have a fagor refrigerator that freezes everything. any advice
Make sure your filters are clean also nothing blocking air flow check and clean front vent
Sep 21, 2017 | Fagor Refrigerators
Fagor dishwasher not completing cycle showing f6
The heater or thermostat is faulty and not allowing the dishwasher to complete cycle as water is not getting hot enough. Try to run a cold or short cycle and see if is completed.
see explanation of fault codes in this manual.
http://www.fagor.co.uk/documents/LFU-65iT.pdf
Sep 21, 2014 | Fagor Dishwashers
Fagor dishwasher showing f6
Please check fault codes on page 70 in this manual.
F6 would mean the water is not getting heated. I am not sure which model you have but if there is only a cold water inlet connection then either heater or thermostat is faulty. If you have both hot and cold water inlet then you may have to check if hot water is getting in at right temperature. Easiest way to confirm is to run dishwasher in cold cycle (short rinse) and see if it goes through. The heater would get used in warm/ hot wash cycles and drying.
Sep 19, 2014 | Fagor Dishwashers
Need manual for fagor splendid
Here is the manual for the Fagor Splendid Pressure cooker!
http://www.hippressurecooking.com/fagor-splendid-pressure-cooker-manual/
Jan 13, 2013 | Fagor Elite/splendid Helper Handle
Fagor F1-48W dishwasher won't fill
this must be a water flow problem to machine , id look real carefull at valves under sink or under floor of machine to see that there open and there are no kinks in hose connecting to it , other than that the one only other reason that it would not add water is that it thinks there's water in it already
Dec 21, 2012 | Fagor Dishwashers
Fagor lf-017s
the water level float is stuck in the "UP" position
Dec 09, 2012 | Fagor Dishwashers
Fagor cr-22 is not working and showing 3 flashing lights alternatively left and right? what is the problem
you should always use just about one tablespoon of white vinegar added to a potful of cold water, poured into your coffee maker, followed by one full pot of plain cold water to rinse thoroughly.....I think using at least 2-3 full pots of cold water to rinse should fix the problem. Of course you realize you have to have the pot on each time you pass water through it, as if you were making coffee. I think calcium cleaaners are too harsh otherwise. [email protected]
Feb 18, 2012 | Fagor Coffee Makers & Espresso Machines
Fagor refrigerator (3FCA-68NFX): no cold air in the refrigerator
u may have a duct that goes from the freezer to the fridge that is closed off or u may have a stopped up freon line and if thats the case ur probably going to have to call a tech but check the duct first if u have one in that particular fridge
Mar 01, 2010 | Fagor 3FCA-68NFX Stainless Steel ...
Fagor cook top connection
Guy from Fagor said brown & blue go to black & red. White and ground together go to green & yellow. Hope he's right.
Apr 04, 2009 | Fagor 31 in. VFA-78S Electric Cooktop
Fagor 3FCA-68NFX Stainless Steel  Refrigerator Logo
82 people viewed this question
Top Fagor Refrigerators Experts
Marvin
Marvin
Arnie Burke
Arnie Burke
Tom Chichester
Are you a Fagor Refrigerator Expert? Answer questions, earn points and help others
