Refer to your service manual or I recommend contacting your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
SOURCE: McCulloch,Mac 3200 Chainsaw fuel lines...........
If you can not find help in your area try Southern Supply Co. Their number is 205-833-2525 and they have anything you will need for McCu8lloch products and they will ship anywhere. Ask for Jason. I hope this helps.
SOURCE: Gas, Oil Mix ratio for McCulloch Eager ******
Fuel/Oil Mixture
Lou
SOURCE: need to peplace fuel line in gas tank.whats the easy way to do i
Watch the video, bar far the best method I have found.
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
• The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
• If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
• The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly.
SOURCE: I have a Mcculloch 16in maccat 35cc chain saw
Does the chain turn freely by hand? Is it being oiled properly? Check the fuel filter, air cleaner, and muffler for plugging. Does 'feathering' the choke make any difference? If it helps, try turning the H jet needle CCW about 1/4 turn which should make it run more rich and 4-stroke until you are cutting which should immediately cause the engine to 2-stroke. Hope some of this helps!
SOURCE: new chain for 16'' 35 cc mcculloch
PartsBuggy.com has all the bars and chains you need for your saw listed here.
