Question about Mercury Mark 30 Hipo Outboard Motor (Mercury Marine)
1977 9.8 hp Mercury Outboard Motor Serrial # 4605112, it's an electric start with a short shaft
I have a 1977 9.8 hp Mecury that needs the water pump impeller replaced.
Posted by Melvin Jackson on
william moore
    Novelist:
  • 184 Answers
Put it in forward gear. Drop the lower off by releasing the bolts and nuts holding it holding the lower on. (one is hiding under the back pick up screen)- some models had a plug in the back top of the exhaust/intermediate housing hiding an allen head bolt pointing down.
Once released, put a protector in a vise and clamp the lower to the bench.
2 screws or bolts will hold the water pump cover on. (the drive shaft runs thru it) Clean the carbon and rust off the drive shaft will allow the pump housing and impeller off the lower. Retrieve the funny looking key drive which runs the pump.
Inspect the shaft, the lower unit oil for water. and find all the pieces of the water pump impeller which may have gone places they shouldn't have.- including the outlet tube from the power head. Check this by putting a tube on the end and blowing- you should hear and feel the pressure in the exhaust and tell tale hole.
Now take the model number , the old pump parts to the marina for a replacement. Do a side by side comparison at the marina so you get the right stuff. Check the inside drive of the rubber impeller and see if they are exactly the same.
NOW- put the new wear plate / gaskets and drive key on, hold in place with grease. Slide the impeller on the key and spin the drive in both directions to be sure it has the impeller and will securely turn it.
Put grease in the cup of the pump housing to prevent dry start and help seat the impeller blades. Spin the shaft as you lower the housing in the pump so the blades all face in the right direction (clockwise). Screw in the bolts. Grease up the seal the watertube goes in and the spline end of the drive shaft.
Up the hole it all goes, now you only have to spline the shifter (it hasn't moved has it?) The drive shaft and the water tube all at the same time.
Check the shifter for correct position and bolt it down
Posted on Jul 29, 2012
1 Related Answer
Tefa222
  • 4 Answers
SOURCE: 80 hp mercury outboard starts and runs as long as you hold the key in the start possition. when you let the key go to the run possition it shuts off any help
Contacts in your ignition switch are corroded. Some can be cleaned but some just have to be replaced at times.
Posted on May 22, 2012
1977 6hp evinrude water pump direction
The drive shaft going to the lower unit through the water pump turns clock wise. If installing a new impeller, put a little liquid dish soap on it to lube it. While pushing the pump housing down, turn the drive shaft clock wise and this will seat the impeller in the right direction. Hope this helps.
Nov 04, 2016 | Boating
We replaced the water pump on a 1990 Evinrude 25 hp motor, but it isn't working. Can you help us?
It may look easy in the book but there are a few things that can go out. Such as the key/roll pin that drives the impeller can slip out on assembly. Water tube out of hole or damaged OR pieces of old impeller in it depending on why you needed to replace it. There are more but if you are not a trained tech it may be time to find one.
Nov 29, 2014 | Clymer Evinrude/Johnson 2-40 HP Outboards...
How to remove the impeller in a gould 1/3 hp water pump
most impellers are simply thread on. in most cases, there is a flat spot or allen key insert at the back end of the motor shaft. this allows you to hold the shaft in place as you unscrew the impeller by hand
Sep 08, 2014 | Pool & Spa
Can't get 1976 evinrude 6hp to pump water I changed water pump
have you changed the impeller inside the lower unit.
There is copper pipe to redirect water up into the engine.
When you replaced the impeller make the copper pipe is insert onto the engine.
Jul 31, 2012 | Light Outboard Motor Boat Bass Fishing...
I have- starite pump it was working fine last night but this morning there was no pressure at all i wonder if is the water tank the pump is running fine but there is no water
It sounds like you have blown your shaft-seal. When this happens the pump runs dry. If you know that you have water but it will not pump, and all the cover and housing o-rings are good, it is the shaft seal. (unless the internal impeller is just broke, but this is unlikely)
Fix: Turn off power. Remove V-clamp holding wet end together. Remove diffuser inside wet end (need flathead screwdriver).
next remove rear electrical panel on the motor. Using s 7/16" wrend, hold the end of the motor shaft by the electrical end (where you removed the cover) while turning the impeller counter clockwise (note: some impellers have an impeller screw inside which unthreads CLOCKWISE) untill impeller is off. Replace carbon shaft seal inside. Reverse and prime and then restore power and start.
Oct 20, 2010 | Sta Rite StaRite DuraGlas Pump 34 HP...
Our pump was running dry for at least a day because a leak dropped the water level below the skimmer. it runs on 220 and sounds like it's running but no water movement in or out. i need a new pump, right?
not necessarily if running may need to be bleed[air bound and need to let out air ]or may need to be primed if there is a bleeder on pump housing un- screw to release air until water runs out --- if still no water pumping may have damaged the impeller depending on ur pump may have to only replace impeller or pump housing
Jul 20, 2010 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
Removal of Aqua-Flo pump from motor
You will need to pull the front of the pump off then unscrew the impeller. The impeller will be set on the shaft and will take some force to break free. Hold ing the back of the shaft and using water pump pliers on the face of the impeller will usually work but sometimes I will wedge a screwdriver in the fin of the impeller and hit it sharply (not hard) with a hammer to break it free. Then the housing will just pull free of the motor. When replaceing, the impeller just goes on hand tight. Hope this helps and good luck.
Apr 15, 2010 | Aqua Flo 1 HP Aqua-Flo Pump: 1.5" in/out,...
Mercury Mark 30 Hipo Outboard Motor (Mercury Marine) Logo
379 people viewed this question
Top Mercury Boating Experts
Colin Stickland
Colin Stickland
Mike
ray gallant
Are you a Mercury Boating Expert? Answer questions, earn points and help others
