Peavey SP2 PA Passive Speaker Logo
Dleahy Posted on Jul 28, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Peavey sp2xt speakers horn makes no sound when plugged into normal input. Horn works fine when plugged into the high side of the crossover.
Tim Davies
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 18, 2015
Tim Davies
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
506
Points
Change the light bulb!
Power Electronics
Level 2:
Champion:
  • Expert 243 Answers
  • Posted on Nov 06, 2013
Power Electronics
Expert
Level 2:
Champion:
Answers
243
Questions
Helped
61710
Points
270
High side speaker input jack defective, as they are switch also and if you plug the wire from the amp in full range and no hf sound but connecting directly to the bi-amp hi does, then your female 1/4 plug at crossover is defective for sure.
I have a pair of peavey sp-2xt speakers if i use the full range input the horn would not work but if i plug it direct to the hi input it works .any sugestions to fix problem thanks
There is possibly a bad solder connection or component on the crossover. I cant remember if that crossover uses a 12volt light bulb or not, for DC current protection, if it does make sure the bulb is good.
1helpful
PROPER WIRING FOR ATTACHING CROSSOVER TO PEAVEY SP4G SPEAKERS.
In Peavey cabinets, the lower woofer is always Yellow + and Blue - and the horn is always Red + and Black -. On the middle 15" the remaining two wires would be White + and Blue -
Horns dont work on both sp2 ti
diaphrams, the high input is a direct connection the the horn.
Why did my Behringer b212d horn stop working.
The problem is bad high freq. IC TDA7293.
There is no pasive crossover.
2answers
Peavey xt22 horn not working
Across the diaphram you should be reading about 8 ohms. it sounds to me like it's blown.However,if you think it'ds thre crossove, take it out and send it to Peavey. They do good , fastwork.............................................................
Mar 23, 2017 • Music
How do i biamp these speakers they have a biamp plug in the rear do i need a special cable to do this
The two input jacks are parallel connected, to allow you to chain extra speakers together. There is no facility on this model to bypass the crossover and bi-amplify horn and driver separately. Nor should you need to. Just make sure you use a power amp rated for at least 400 watts per channel at 8 ohms.
Titanium high frequency drivers not working. Is there a fuse in crossover?
i) I believe you can access the fuse by removing the Input Jack Panel.
ii) If fuse is OK, then unscrew the horn unit, take off one speaker wire & measure resistance. If it is open circuit then you can order a replacement horn diaphragm (if you feel confident to fit it to the horn).
No sound in horn when plugged in bi amp connection
The question is whether or not you get any sound from the horn when in full-range. If so, then either the input jack for the horn is defective, or you are not passing the signal. A quick check would be to send the full-range signal (at low volume) to the high-freq input. You should hear the horn work. If not then the connector is defective on the crossover board.
If you get no sound from the horn in any configuration, then the coil is blown for the horn. This can be replaced. It is usually a 22a or 22ti diaphram
Let us know what you find.
Dan
Sp5 peavey stop working it is getting the signal and you can pulg another speaker in the normal port and the other speaker works
The "in" and "out" jacks on the speaker are connected in parallel, so the fact that the other speaker works really doesn't tell us much. If you are not getting any sound at all from either the woofer or the horn, than the internal crossover is probably the defective part. The easiest way to hunt this down is to remove the rear plate that has the connectors on it and try each speaker directly,. Assuming that each speaker works, replace the crossover. Parts should be availabel from, Peavey directly. Call them and speak to the service parts department.
Dan
I have a set of peavey scorpion sp5xt's one works fine but if i plug into the other one ,in full range, only the horn works,
Horn and speaker combo cabinets have an electronic component called a "crossover". The horn and speaker both work off different electrical signal frequencies. If you can take off the back, or get inside by pulling the speaker, check for a small circuit board mounted inside the box or on the speaker or horn. Check for a broken wire or loose connection of the crimp connectors.
A common problem with speakers, often the cone, or paper part of the speaker will come un-glued or separated from the magnet "voice coil". This happens when played too loud, when it's commected to the wrong impedance, or if the signal was shorted and "overdriven" (usually sounds like an awful buzz that's really loud).
Always make sure your output impedance matches the impedance of the speaker. Most auto stereos are 4 Ohms. Older home stereos are typically 8 Ohms. Musical PA gear varies between 4, 8, and 16 Ohms. Peavey gear is typicall 4 Ohms, but some older models are different. The Ohm rating is the amount of the resistance in the circuit. If your speaker is 4 Ohms and you plug it into an 8 Ohm circuit, you can destroy the speaker and sometimes the crossover circuit board.
Good Luck.
Jim
[email protected]
Phoenix, Az
Jan 09, 2009 • Music
Top Peavey Music Experts
NOEL
NOEL
Ngoro
Are you a Peavey Music Expert? Answer questions, earn points and help others
