Question about Philips Senseo HD7832 Coffee Maker
Senseo Cofee machine switches itself off after only a few seconds even when water jug full
Posted by gohayon on
2 Related Answers
LuvCreama
  • 17 Answers
SOURCE: one coffee cup button switch not wotking properly after 6 months
Call senseo at 866-4-736-736 866-4-Senseo and describe the problem.
if you have purchased or received it as a gift less than two years ago they will send a new one FREE.
Posted on Feb 03, 2009
LuvCreama
  • 17 Answers
SOURCE: Senseo won't fill itself on initial flush
Sounds like resevoir was not seated properly or something is in the resevoir. try pushing the pin on the bottom of the resevoir, do it over the sink, and see if water comes out. if tht works then its internal to the machine. Call senseo at 866-4-736-736 866-4-Senseo and describe the problem.if you have purchased or received it as a gift less than two years ago they will send a new one FREE.
Senseo is not putting out the water
There is a possibility it just needs more water or it could be 'furred up' because it has not been purged or descaled for a long time. Fill up with water and place a large jug '500ml min' under and press both the single and two cup buttons at the same time. Refer to the user manual for the type of descaler to use.
Aug 14, 2014 | Philips Senseo HD7832 Coffee Maker
Need a descaler
instractions are from manual HD7810/00
Use the correct descaling agent
Only citric acid-based descalers are suitable for descaling the SENSEO
machine. This
type of descaler descales the machine without damaging it. For the correct amount,
see under 'Descaling procedure' below. Each descaling mixture can be used only once.
After use, the descaling mixture is no longer active.
We advise you to use the special SENSEO
Descaler (HD7012/HD7011/HD7006).
Read the instructions on the package of the descaling agent.
Never use a descaling agent based on mineral acids such as sulphuric acid,
hydrochloric acid, sulphamic acid and acetic acid (e.g. vinegar). These descaling
agents may damage your SENSEO
coffee machine.
Descaling procedure
1 Mix 50 grams of citric acid with 1 litre of water in a measuring jug. Stir until
the powder is completely dissolved.
2 Fill the water reservoir up to the MAX indication with the descaler mixture.
Then put the water reservoir back into the coffee machine. (Fig. 3)
Note: Not all SENSEO
machine types have a water reservoir with a capacity of
1 litre. If you have a SENSEO
machine with a smaller water reservoir, repeat steps
2 to 6 with the remainder of the mixture without filling the water reservoir up to
the MAX indication.
3 Press on/off button 3. (Fig. 10)
The machine is ready for use when the indicator light lights up continuously.
4 Place the 1-cup holder h with a used coffee pod in it in the coffee machine.
Close the lid and make sure it is properly locked.
Note: Always put a used coffee pod in the pod holder when you descale the
machine. This pod serves as a 'filter' to prevent the sieve or hole in the pod holder
from getting clogged with scale residue.
5 Put a bowl with a capacity of at least 1500ml under the spout to collect the
descaling mixture (Fig. 8).
6 Press the 2-cup button hhand let the machine operate. Repeat this until
the water reservoir is empty. (Fig. 25)
Never interrupt the descaling process!
7 Repeat steps 1 to 6. Replace the used pod with another used pod to filter out
the scale residue.
Note: To descale properly, you have to use 2 litres of descaling mixture.
Never descale the SENSEO
coffee machine with the lid open. Make sure the lid is
properly locked.
8 Rinse the water reservoir with tap water. Fill the water reservoir up to the
MAX indication with tap water and repeat steps 3 to 6.
Note: Do not refill the water reservoir with used hot water or the used descaling
mixture.
9 Fill the water reservoir with fresh tap water up to the MAX indication again
and repeat steps 3 to 6 once more.
Note: Always rinse the machine by letting it empty two full water reservoirs.
10 Remove the used pad and clean the pod holder after descaling to prevent the
sieve or hole in the centre from getting clogged.
Mar 30, 2014 | Philips Senseo HD-7810 Coffee Maker
Coffee tastes stale even after cleaning
A few things you can do. Buy less pods at a time and store them in a jar. Shake or aerate the water when you put it in the unit. Don't put it in, the night before.
Jul 26, 2009 | Philips Senseo HD-7810 Coffee Maker
One coffee cup button switch not wotking properly after 6 months
Jan 24, 2009 | Philips Senseo HD-7810 Coffee Maker
Senseo machine has started producing very weak coffee
I don't know if you've tried this, but it works like gangbusters for me. I use non-senseo pods with the 2-pod holder, and they're too big for the 1-pod holder but not quite big enough for the 2-pod one.
I would frequently end up with a lousy, weak cup of coffee, and after a little investigation I deduced that water was flowing into the pod holder and AROUND the pod, without going THROUGH the pod directly. The name-brand senseo pods fit perfectly, and always produce a strong cup, even if I don't like their coffee, and it's because there's such a tight seal between where water flows in and where it flows out.
Simple solution: Put your pod in with the flat part facing up, and the bulgy part facing down. Press it down hard into the 2-cup holder. Run a little HOT tap water, and lightly wet the surface of the pod--not so much water that the pod starts floating in the holder, but enough to get it soggy. Then make your cup of coffee. The water will flow through the pod first, and kind of like siphoning gas through a hose, once it's started going through the pod it won't stop. Instant awesome cup.
Oct 24, 2008 | Philips Senseo HD-7810 Coffee Maker
Oct 21, 2008 | Philips Senseo HD-7810 Coffee Maker
Amount of coffee produced
you clean the filter with what vinegar you need to use descaler descaler melt calcium vinegar vinegar remove calcium in pieces that might block the machine use descaler 1 part descaler 1 part water put solution in the water tank start the machine after a few second turn it of wait 10 to 15 minute after repeat untill empty rinse very good 2 or 3 full rinse that stuff is corosif thanks for using fixya pierre
Feb 09, 2008 | Philips Senseo HD-7810 Coffee Maker
Philips Senseo HD7832 Coffee Maker Logo
463 people viewed this question
Top Philips Coffee Makers & Espresso Machines Experts
Piers Carter
Piers Carter
Harrie
Andrew Taylor
Andrew Taylor
Are you a Philips Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
