Question about Cam Spray Cold Water Pressure Washer, 1600 psi, 3 gpm, Honda GC 5 h.p
Honda pressure washer manual
Supply online manual
Posted by daren r. on
Remmy Moore
    President:
  • 1,734 Answers
This is the best site to get ANY Honda manual, just send them a search request and within 2-3 hours you will hold your manual in your fingers.
Posted on Jul 29, 2012
Home lite pressure washer 163 cc do you have parts for this
If you are looking for parts for this machine, you'll need to know the model number; if it is for the engine, the name (Honda, Briggs & Stratton, etc.) and the model number to it. If you still have the owner's manual, there is usually in the appendix, a schematic along with a parts list page.
You can easily go online and enter the "Home lite" brand name of the pressure washer, the model number plus the words owner's manual.
Same thing for the engine.
There are many online manual sources.
Nov 22, 2013 | Garden
I need a owners manual for a pressure wahser GCV 160 from honda
MiTM will have that. See mitm.com Honda makes the motor but not the pressure washer. Honda does have manuals if you need one for that GCV160 motor.
Oct 20, 2012 | Mi T M Chore Master Pressure Washer - 5.5...
I bought a honda pressure washer power boss 3000. I load the gasoline, start the machine, but pressure water is not coming out from the trigger. i tried so many things , but can t get started.
If you are using a water tank for water supply, remove the water supply line from the pressure washer and connect a water hose from a faucet. Turn the water on, then crank the engine. Pull the trigger of the spray gun until water comes out. When then water starts to spray properly the release the trigger, shut engine down with pressure on the line then reconnect the water supply from the tank to the pressure washer. If this fixes the problem then the problem was "air-locked"! Happens alot with new pressure washers that have never been run. If you need any other help, please email me @ [email protected]
Feb 18, 2011 | Honda Pressure Washer PSI 3000
We need a manual for our pressure washer 3700 PSI, 13 HP-GX 390. How do we get this?
The numbers you have listed are for the engine, Honda doesn't actually make pressure washers but makes the engines. If you are looking for the manual on the pressure washer itself you are going to have to find some other numbers that should be listed on the frame of the machine.
Nov 01, 2010 | Honda Garden
Looking for manual for honda pressure washer,its a GX 340 11.0 HP that I can view online without buying so I can find the part and part number
Go to this page:
http://www.jackssmallengines.com/help.cfm
You must have your exact engine model number listed on the side of the engine crankcase near the lower mount and oil plug.
Thanks for choosing FiXya.
Kelly
Jun 23, 2010 | Honda Pressure Washer PSI 3000
Hi I just bought a Honda pressure washer. The
You just bought it which means it is under warranty. Take it back where you bought it or call Honda. You must have the vent plug installed to use the machine. If it is blowing oil out the vent plug then it is either overfull or it is building up pressure for some reason. Make sure it is not overfull and if not, then call Honda and avail yourself of the warranty. If it is overfull, remove enough oil to get it to the proper level.
Apr 16, 2010 | Honda Maxus Pressure Washer MX5222
My pressure washer has pressure but not nearly as strong as to what I'm used to
hello....
Sorry, but have to ask the basics: Have you replace the nozzle to account for wear? Have you checked the inlet (garden hose) pressure and line supply to be sure it is clean and enough gpm's to supply machine? Is the supply pressure too high, so that the packings inside the pump may have been damaged? Have you removed the brass caps on the pump to clean out the little spring valves and check the o-rings?
Jan 17, 2010 | Honda Pressure Washer PSI 3000
Cam Spray Cold Water Pressure Washer, 1600 psi, 3 gpm, Honda GC 5 h.p Logo
637 people viewed this question
Top Cam Spray Garden Experts
John Trevino
russlakeside
Level 1 Expert
Are you a Cam Spray Garden Expert? Answer questions, earn points and help others
