Pentax ZX-50 35mm SLR Camera Logo
Question about Pentax ZX-50 35mm SLR Camera
How to load film into pentax zx-50 - Pentax ZX-50 35mm SLR Camera
5 Related Answers
poolseman
zdenek vajdak
  • 206 Answers
SOURCE: Pentax zx-50 Shutter Problems?
I really think this is the classic zx - 50 shutter motor problem : small motor on the side of the mirror box is not cocking the shutter . This is very repairable but unfortunately it requires fair amount stripping down of the camera to get to the fault and so you will have to take it in for repairs.
Posted on Sep 03, 2007
Anonymous
SOURCE: Pentax zx 50 35mm slr
Others here have suggested the problem lays with the plastic gear on the advancing motor beside the mirror.
This might cost $100 or so...?
Posted on Jan 24, 2009
Anonymous
  • 11967 Answers
SOURCE: can the shutter curtain be replaced on a Pentax
It can be replaced only by a trained service technician. Check the Pentax website for a service center near you.
Posted on Aug 12, 2009
Anonymous
  • 571 Answers
SOURCE: my pentax zx-m rewinds new film as soon as i shut
When loading film, make sure to draw the film all the way to the receiving spool. If you don't pull the film far enough the camera thinks it's empty and rewinds the film.
Posted on Aug 18, 2009
Anonymous
  • 2702 Answers
SOURCE: The shutter on my Pentax zx-50 SLR is stuck in the
if its just a sticky mirror you could try to very genteely flip it down again but if the shutter is jamed in its sliders it could need to go to a camera shop to get it "fully serviced!" also check its not just the shutter lock button stuck in, or the shutter is locked open,
Posted on Nov 28, 2010
I don't know how to load my film into my pentax zx-7
Download the manual from http://www.butkus.org/chinon/pentax.htm and follow the instruction therein.
Camera shoots all the film then rewinds.
Repair would be at least $139 from Blue Moon Camera. I would buy another MZ-50 (ZX-50 is the same) off eBay or you could buy a ZX-30 from Blue Moon Camera for $75 with 1 year warranty. They are professional.
http://www.bluemooncamera.com/services.php
What is the best film to use in the ZX-50
use ISO Kodak 400 as a start. Remember that the higher the speed the higher the grain. So if you want to enlarge to poster size a lower ISO speed will give the less grain, ( sharper image ).
My pentax zx-m rewinds new film as soon as i shut the door
CAMERA EATS FILM
When loading film, pull it all the way to the receiving spool.
My film won't load
Jammed Advance Motor Assembly.
Camera inoperable
According to the manual found here:
http://www.pentaximaging.com/files/manual/ZX50.pdf
It says, "If the film is not loaded properly, 'E' on the LCD panel blinks, indicating that the film is not loaded properly. Open the back cover and load the film once again."
Film not advancing fully
Are you sure that you have loaded the film properly?
Sometimes if you have not started the film so that the sprocket pulls the film correctly the film can aquire slack and the teeth of the sprocket may not be successfully pulling the film from the canister each time.
2answers
Top Pentax Photography Experts
Bill Eager
Are you a Pentax Photography Expert? Answer questions, earn points and help others
