Kenwood KDC-MP342U Car CD Player Logo
jerry guthrie Posted on Jul 28, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenwood kdc-mp342u wiring colors or codes
Wiring colors
  • Anonymous Jun 21, 2013
    hello i want only the FACE PLATE for a Kenwood KDC-MP342U CAR STEREO
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Kenwood Master 102,366 Answers
  • Posted on Jul 28, 2012
Kenwood Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10443645
Points
622693
The wiring diagram is on page 20 of the manual.
5 Related Answers
foskorider
Brandon Kennison
  • 79 Answers
  • Posted on May 18, 2009
SOURCE: kenwood kdc-x491 wiring diagram
red, yellow, black/ign constant ground
blue, blue white stripe/rem pwr ant
grays, whites, purples, greens/ front front rear rear
its the same on all headunits except cheap *** wal mart headunits
Anonymous
  • 34 Answers
  • Posted on Jan 08, 2009
SOURCE: UNLOCK SECURITY CODE
for your kdc-mp528 will work whith code KCAR entered from the remote
Common Kenwood Security Codes
Many Kenwood radios are configured with the same security codes:
KCAR - This seems to be a "backdoor" to some Kenwood models.
3051 - This is the security code which is printed in the manual of many Kenwood models.
1234 - This is a security code commonly chosen by Kenwood owners.
Entering Your Kenwood Security Code
If the car battery fails or is disconnected, the Kenwood will ask for the security code.
The procedure to enter your security code differs on various models of Kenwood car stereos. Here are three of the more common procedures:
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds until the "..." display disappears.
Enter the security code using your Kenwood remote.
Type 2
Press and hold the "Auto" button and "Track up" (next track button on the right) on the face of radio at the same time until the four dash lines disappear.
Type 3: Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset keys until the display shows the letter 'C'.
Entering Letters on your Kenwood Remote
To enter a letter using your Kenwood remote, press a button once for the first letter, twice for the second letter, and three times for the third letter -- then press the Track Up or Next Track key to send the letter.
To send the letter 'A', press the 2 key once and then press the Track Up key. To send the letter 'B', press the 2 key twice and then press the Track up key.
Finally, when you are done entering all of the letters, press and hold the Track Up button for 3 seconds.
The key sequence to enter the security code KCAR is:
5
5
Track Up
Track Up
Track Up
7
7
Track Up
Your Kenwood should then enter tuner mode.
A Security Code Bug in some Kenwoods
There is a reported bug in the security code handling of some Kenwood stereos. In models with thie bug, the security code is stored incorrectly. The workaround is to enter the wrong security code.
In models with this bug, you have to decrement the third character of the security code by one. If your security code was 1111, you would enter your security code as 1101. If your security code was 9999, you would enter 9989.
i hope this works for you.
smarthome2
Frank Fulton
  • 1114 Answers
  • Posted on Aug 17, 2009
SOURCE: I was given a Kenwood KDC-1011S. All wires labled
Yellow is for constant 12v. (Power directly from battery) so it maintains preset stations and clock memory. Red is for Key "on" 12v Power (turns on when ignition key is on) Black is for Chasis Ground. What type of vehicle is it going in? I can get you the corresponding vehicle color as well. Post a comment with make/model & year vehicle. Hope this helps.
Anonymous
  • Posted on Nov 02, 2008
SOURCE: Kenwood KDC-3028 unlock code
TY TY TY..fixed this right on up. Only suggestion I could make is that a diagram of where the aforementioned buttons are. I did mine at night so the small words were hard to see. I just replaced my battery and cleaned off the cables connectors when this problem occurred. TY so much for this.
Anonymous
  • Posted on Feb 12, 2010
SOURCE: how can i deactivate the protect that blinks in my
Disconnecting the terminal will take to much time.. In between the skip button ,and the #1 on your stereo there is a little dot. Barely noticable unless you know what your looking for, take a safety pin or a screw( anything with a little tip) and push it in. This will restart your stereo. (Car Must be on)
2answers
My battery died and I had to get a new battery. I can not remember the security code for the car radio KDC-MP342u can you help?
You may have to contact the manufacturer for details on that. Check in your owners manual for the phone number of their customer service. I had a similar problem after changing battery but found the answer right in the manual. Mine was a Kia.
I cant find the kenwood factory code for a kdc-mp342u radio
You can enter a 4-digit security code which must be used when the unit is removed from the vehicle, or the constant power source is disconnected from the unit. When constant power is restored to the unit, the security code must be entered before the unit becomes operational.
If the code is lost or forgotten I am afraid the unit has to be re-coded by a Kenwood dealer.
Good luck with it.
How do you wire a kdc-mp342u in a ford mustang w/o a harness?
Standard radio color code as follows:RED=switched ignition +12v YELLOw=+12 volt battery(always hot), BLACK= ground, BLUE=remote turn on for amp, OrANGE=light dimmer, White and white/blk= left front , gray and gray/blk= right front, green and green/blk=left rear, violet and violet/blk= right rear
I got a new battery put in my car and now the radio is asking for a security code. I have a Kenwood KDC-MP342U...Please help
you have a code in the back of the manual that you have to enter into the radio if you dont have the manual call kenwood hotline they will give it to you for free
22helpful
I have a Kenwood car stereo model # KDC-MP342U. Protect mode has been activated on it. I found I had a frayed wire on a speaker from window movement and have replaced the wire. When I reset the radio and...
hold down preset 3 & 6 + reset
press preset 1 - shows dc err
press preset 1 - shows dc ok
press preset 2 - shows dc 2-4
press preset 2 - shows dc 2-0
then unit should be ok with eeprom reset
The screen on my KDC-MP342U just blinks with the word PROTECT
first, check your speakers and speaker wires for shorts, then disconnect power to the radio for a few seconds and reconnect it. if that doesn't work, then you probably have a bad output ic.
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
