Question about Maytag Atlantis MAV6000 Top Load Washer
I have a Maytag Atlantis washer Model # MAVT754EWW. I want to clean the hose Screens that attach to the washer. I can't do it from the rear ( you need a special tool ) to remove the hoses to clean the screens. I would like to go in from the top by lifting the top of the washer to get in and clean the screens. the is access from the to.
Posted by Greg Stanley on
  • fuelr63 May 11, 2010
    do you need to get the top open ?
NOEL
    Top Expert:
  • Maytag Master
  • 8,546 Answers
5 Related Answers
Lumpy816
Toby Norton
  • 246 Answers
SOURCE: Maytag Atlantis washer will not drain and spin unless you lift the lid
The cheaper thing to check first is is your lid bent? The lid switch is in the center of the lid. If it "droops" or has been bent, it shaft on the back of the lid cant hit the switch. Open the lid and apply pressure in the bottom, center of the lid. This usually corrects the problem without replacing the switch.
Posted on Jun 16, 2008
JEFF SIEGEL
  • 311 Answers
SOURCE: My washer won't spin clothes. I
Typically the plastic pulley is worn down at the bottom of the machine if the motor runs and the unit does not spin. There is a pulley kit to replace it. Sort of hard to do; may want the reapir man. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Posted on Nov 30, 2008
Anonymous
SOURCE: maytag washing machine leak
I've got the same problem going on. You can take the front off the machine . Its two panels held on by four screws. This will expose the "guts of the machine, plus you can lift the top up, but not really enough to do a major repair. You will be able to see the water leaking though. Good luck. I bought mine used about three years ago and am thinking its not worth fixing. The machine I'm guessing is about 8=9 years old. If your looking for a used machine, you might want to check with a "Resale" type store. We have a Habitat for Humanity Resale store that gets good used appliances in sometimes. Of course, whenever you buy used, your taking a chance. However, when you look at the cost of new ones compared to used ones a couple of years old, it might be worth it. I looked at Maytags at my local Lowes, and they were about $600.00. Used ones are about $100.00. Good luck. Hope things work out for you.
Posted on Jan 03, 2009
onthejob5130
onthethejob1
  • 640 Answers
SOURCE: maytag Atlantis top load washer
ok just a touch of help for ,,onthejob...i need you to start at a cycle and put unit on cold cold,,ok...now i want you to put your hand on back of unit where the inlet vavle and the hose meet at unit...do you feel a vibebration,,or here it humming,,now if hot water comes though,,all you have to do is reverse the hoses there on wrong,,im here onthejob
Kolawole Ayede
  • 327 Answers
SOURCE: My washer gives an nF code. I have disconnected
Hello,The "nf" code is a "no-fill" fault. This indicates that your washing is not getting water supplied to it, or the pressure isn't substantial enough to complete a fill. You need to, first, make sure the water supply is turned on. Second, if the water IS turned on, and you're still not getting anything to your washer, you may have a fill valve problem. The fill valve is what both your hoses connect to on the back of the machine. It can become clogged with sediment over time (especially, if you have hard water or well water). Turn the water supply off and remove both hoses from the back of the washer. Check both these hose connections for clogs in the filter screens. If they are clear, then more than likely the fill valve has gone bad.
Thanks
Posted on May 28, 2010
Maytag atlantis washer #mavt754eww washer starts fills up then the motor squeals and washer stop and would not agitate or run.
Your model has only one belt that goes around motor, transmission, and drain pump pulleys. Most likely it is the cam bearing kit that has worn. That kit includes the big yellow pulley under machine at center and btake cam and associated washers and bearing. It also could be drain Pump seized up or could be motor is bad.
Nov 01, 2017 | Maytag Washing Machines
I have a maytag Atlantis washer - 7 years old, it
I have a Maytag Atlantis top load washer which leaks in the rear right hand corner under the discharge hose, how do I take the machine apart to get to the problem.
Feb 04, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Washing machine is very slow on a hot fill setting.It takes 45mins for the water to come through
You have a bad water valve a clogged water valve or crappy hoses. If you is using flood hoses toss em. Remove and clean the inlet screens on the water valve. Check valve for continuity and hit it with juice to see if the mechanics are functioning within.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 24, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Water continues to drip into the washer when it is finished with cycle and turned off
Water valve is located at the rear of the machine with the water hoses attached to it. Disconnect power. Remove hoses and unscrew the small angled bracket attached to the valve. Replace the valve and your problem will be solved. Part Number is 2200270. This the only possible cause for the symptom you describe.
Oct 12, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis 7700 AWW - no cold water wash or rinse Everything else works fine
Look for a cold water supply problem, since cold water is what is used in the rinse. Check the water inlet valve. Remove the water supply hoses and check the small screens inside the water inlet valve. Make sure they are clean of rust or debris. The solenoids can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty solenoid. I will attach a photo for reference. Hope this helped and best wishes.
Aug 19, 2009 | Maytag MAV7600 Top Load Washer
I have a Maytag Atlantis MAVT754EWW machine and there is a black soot like substance being left on the floor under the washer. It smells like rubber - do I need to replace the belt and if so, how do I do...
this black soot like substance is the motor carbon brush dust. i would get the motor brushes replaced and clean off all the dust from the pulleys and also replace the belt as it has been slipping on the dust.
Mar 18, 2009 | Hotpoint Aquarius WMA52 Front Load Washer
Maytag Atlantis MAV7600AWQ Washer. Delayed fill
ALL WASHERS COME WITH SCREENS AT THE
WATER CONNECTIONS.DISCONNECT THE HOSES AFTER TURNING OFF THE WATER.THEN,CHECK THE SCREENS FOR MINERAL BUILDUP.CLEAN THE SCREENS IF
NEEDED AND GO FROM THERE.
Mar 07, 2009 | Maytag MAV7600 Top Load Washer
Maytag Atlantis top load washer that wont' let cold water cycle through. Water is always hot or luke warm. checked screens on hoses. Any suggestions?
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Nov 30, 2008 | Maytag Washing Machines
Maytag Atlantis MAV6451AWW
turn off the water and remove the hoses from both the wall and from the back of the machine. check the screens inside of the machines water valve, they are probably clogged. do the same for the hose screens on the other end. replace the hose screens at the wall end and remove the screens from inside the machine. replace hoses and turn the water on and you should be good to go
Sep 19, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
220 people viewed this question
Top Maytag Washing Machines Experts
John Tripp
John Tripp
jdthefixer
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
