Wont turn on and blue and red lights on soild
SOURCE: Pioneer PDP 5030 power supply problem
Ok here's how I manage solve the problem... Having the back removed opens the contacts on the interlock switch so I guess if it powers up in this state it senses the high voltages are exposed and for safety shuts down... After this the unit will not power up and the power led flashes red continuously as described before…
After some thought it occurred to me that there may not be a problem at all, just be a simple reset function for this condition… I managed to find an easy solution to this… Just call up the hidden engineer’s service menu – On 3rd generation Pioneer Plasmas it’s as follows > Power down the screen > Hold down the “Input” and “Vol +” buttons on the front > Power the screen up and the Service menu comes up on the screen > You don't need to change anything just simply power off and from then the screen should operate as normal…It did for me so I’m well happy now!!
I hope this information will help someone else one day – Good Luck!!…Rob UK…
SOURCE: Pioneer PDP-503PU
Very possible,but yet,this might be the manufacturer defect power supply which they will fix it for you free;but before we jump to this conclusion,you need to test it first:
-Unplug the power cords.
-Unplug the media video cable from the box to the tv.
-Check all the pins on the video cable are in place as well as the connectors both behind the TV and the media box.
-Reconnect the media box and TV with the video cable(DVI+VGA in one) and have at least a video component hook up to it(ex. dvd player/VCR or comcast box) be sure this video player is turn on and running,at the same time,be sure it is under the right video input.
If you have tried the above steps but still doesn't work,call 1-800-pioneer Tuesday-Thursday at7amPST and address your issue to them.
Let me know if you have any additional questions!
solutiondoct
SOURCE: Pioneer PDP-5030HD power supply
click link -ebay shop selling power supply boards for 503hde/pe at 180 pounds you will have to contact him has he does not list them as pioneer are only ment to replace these boards or shops under contract with pioneer i changed mine and only takes min's when you have got the back cover off...
http://stores.ebay.co.uk/Plasma-Parts-UK
hope this helps mark doran
SOURCE: pioneer media receiver won t turn on
If the light on the media reciever doesn't come on then the power supply in that needs to be replaced by a service tech. If you disconnect the 2 cables from the media reciever and the panel and then try to turn on the panel it should light with red and green squares for a few seconds but will turn off as it needs the media reciever to be connected.
