Question about Invacare Supply Group Invacare Scooter Lynx L-3 L-4 Transaxle Differential
Lynx scooter full charge will not move
I have my Father's Lynx scooter, when he passed away I thought my Mother would need it but she never used. Thought to sell it, bought new batteries, charged fine reads full but the scooter won't move. I was tracing wires and playing around with the "neck" bending back and forth and it did start. Ran for a while, I put back in garage a couple days later won't move. It's in free wheel mode, wiring is like brand new only used for 2 weeks but is 12 years old. Any ideas?
Posted by Rick Weiler on
Dan Apthorp
  • 2,824 Answers
Sounds like a wire has broken or come apart. If playing with the neck it starts sometimes that is the area that could be the problem.
Posted on Oct 14, 2018
5 Related Answers
oregoon
  • 175 Answers
SOURCE: My wife has an Invacare Buzz scooter - I have got
The Buzz breaks down into four pieces for transport. Electrical connections must be unclipped to separate it completely. It is possible that one of the connections isn't completely clipped together, so my first check (after you have made sure that you have it plugged into a working outlet!), would be to take it apart and then reconnect everything firmly. While you are at it, you should look for any other clip-connections and undo, then redo all of them. Even those that "look okay". Inspect the connections metal fittings for signs of corrosion or dirt that may be causing a high-resistance connection, and clean as necessary. Run you fingers along the wiring to check for any places that my have been damaged, breaking a wire connetion in mid-stream. Make sure the connections to the batteries are clean and free of any corrosion too. Be sure to check the fuses to make sure you haven't blown one, and also push in your circuit breaker. These sometimes trip while charging due to spikes caused by thunderstorms. If you do all this and it still isn't charging, you'll need to open the shroud at the head of the tiller and inspect the connections running up inside the tiller, and the connections going to the PC board located at the very top of the shroud where the thmb-paddles hook into the electrical system. There should be a fuse inside there too, so check that.
Good luck.
Posted on Jul 11, 2009
Barry Nixon
  • 103 Answers
SOURCE: Have an invacare patriot LX4. Unit takes full
Check to see if the scooter is in freewheel mode. To know if the batteries are bad you need to charge them for 10 - 12 hours and then have them tested with a load tester.
Posted on Jul 29, 2009
gewiz
Rob Hill
  • 1414 Answers
SOURCE: our patient has lost the user and operation manuel
Hi , I cannot locate the lynx 4 manual however I have located a lynx 3 manual with I been told is similar.
http://www.rentascooter.com/downloads/_manuals/invacare/Invacare%20Zoom-3%20Lynx%20and%20Panther%20Series%20Owner's%20Manual.pdf
Regards
GeWiz.
Posted on Oct 24, 2009
Titilayo Sodipe
  • 1428 Answers
SOURCE: What is Invacare Supply Group?
Really i don't know the charge. Contact Fixya Team on [email protected]
Visit http://safemanuals.com/user-guide-instructions-owner-manual/LYNX/4TS630A-_E
Cheers
Posted on Mar 11, 2010
plaztiksr4me
Nick Kostohryz
  • 154 Answers
SOURCE: when trying to charge battery the light on the
if it is an old one you may have a burned out motor. the blinking is a code find the manual it should tell you what the flashing code is.
Posted on Apr 09, 2010
Rio 4 lightweight light flashes but doesn't drive
hi, please can you tell the number of flashes before a pause then it starts flashing again ?
Regards
Rob
www.gewizrepairs.co.uk
Mar 23, 2014 | Invacare Lynx 3-Wheel Lightweight Portable...
Lynx l3 dead
hi, Are you sure then battery box is fitted correctly ? you need to make sure the battery box is supplying a voltage to the scooter, there is a fuse located within the box however it rare to blow this unless you used a higher amp charger , normally more than 5 amps, this type of charger would be for a 8 mph scooter etc.
IF you have access to a electrical meter plug the two probes into the outside pins of the charger socket , do not allow them to touch, measure the voltage, no voltage then the fuse has gone or a contact has come off the battery
IF you located anywhere near me SS16 then testing is free.
Regards
Dec 27, 2012 | Invacare Supply Group Invacare Lynx L3...
Have bought a second hand DMA Tinto S534 mobility scooter for my father and would appreciate an instruction manual or at least some basic information.
Hi peters_17,
Just bought one of these myself second hand, managed to find this on that t'interweb thingy.
http://www.merits.com.tw/upfiles/news01191893408.pdf
You may not need this anymore, but, could come in useful for someone else.
Regards.
Kevin
Jul 28, 2011 | Health & Beauty
We've just bought this scooter on eBay and the seller doesn't have a manual or anything with it. We've not had one before so we thought you could maybe help us to obtain one?
It will me my pleasure to help you find the manual, can you please provide me with the brand and model of the scooter?
Thanks
Jun 14, 2011 | Health & Beauty
I have an invacare ride on . The battery charger failed after the storm. Are they repairable or do I need a new one. If so, how much do they cost
The battery charger for this scooter is available from:
http://www.monsterscooterparts.com/
I believe the original equipment charger from Invacare for this scooter was a 3 Amp off board or on-board charger. The charger is no longer available from Invacare. Monster scooter parts shows this as a 2 Amp charger for the Lynx.
It would be more expensive to repair this charger than to replace it since you indicate it failed after a storm power surge. You will be happier by replacing the off-board or on-board charger for a price between $50 and $150. The only cost effective charger repair is the cord or plugs.
If the charger was plugged in during the storm, I would check the power path on the scooter for burnt fuses and wiring. Hope this helps.
Dec 30, 2010 | Invacare Supply Group Invacare Scooter...
My Father in Law passed away and I am trying to get his Craftsman 5hp wood chipper running so that my Mother in Law can sell it. It has electric start. I assume with electric start there must be a battery...
You can visit the Craftsman website to get this info. You will need your Model Number and Serial number to download an owners manual. The manual should show you where the battery is.
Apr 19, 2010 | Heavy Machinery
Please I need a timer for a Potterton timer EP2003
Dear dm:
Sory to know about your father.
I think the best to do in this situation , if you can afford it, is to look for a certified electrician to take care of that timer . May be you will have to buy a new, "user friendly timer" to control your water system.
Hope this helps.
emiliosan
Dec 27, 2008 | Hardware & Accessories
Open Questions:
See all Invacare Supply Group Invacare Scooter Lynx L-3 Questions
Invacare Supply Group Invacare Scooter Lynx L-3 L-4 Transaxle Differential Logo
777 people viewed this question
Top Invacare Supply Group Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Lawrence Oravetz
Are you an Invacare Supply Group Health and Beauty Expert? Answer questions, earn points and help others
