Have tried leaving on to see if it will reset tna
AIR JET PUMP ERROR CODE GCF
Grounding/Earthing fault. This indicates a problem with you mains supply. Also can occur if you are using an extension lead. If you are plugging directly into the mains and get this code, you should get a qualified electrician to ensure your supply is correctly fitted. If this is confirmed, then there is an internal fault with the pump and you will need to contact Bestway.
We hope that you never encounter any of these error codes on your Bestway Lay-Z-Spa hot tub. Whether you own one or hire a hot tub, this guide will hopefully get you back to enjoying your hot tub in the shortest time possible.
Poor earth supply through your rcd plug which need replacing in 90% of most cases you can unscrew top and bottom of rcd check screws are tight.
How can i solve this problem?
SOURCE: layz spa keeps going off says on readout
You have a problem with the RCD (residual-current device). This is the part of the plug that you have to push reset on before a current will flow. You can repair this by buying a new RCD plug and rewiring it or if you already have an RCD socket adaptor for another appliance, you can just cut of the plug on the pod/ pump and rewire it into a rubber plug and then plug this into the RCD adaptor and the lay z spa should no longer cut out. The RCD is important because you do not want to blow the unit inside.
I hope this helps, If you need more assistance, please ask.
6cf is actually no connection to ground manual page 8. Check your plug and socket, replace extension lead.
Hi I've just bought a palm springs lazy spa unable to even inflate it because it says 6cf tried everything new plug resets changed different sockets still just beeps and says 6cf please can you help
Same problem for me
Same problem here. I had the electrician out and our ground loop impedance is 0.19 ohms, well within Part P spec. We have no faults on our house of any type. The pump has the same error on other houses down our road... Whatever this is detecting is more sensitive than 0.19 ohms, which is well within spec or its actually detecting something else. We are in the queue for their support. I assume this is a fatal error and It will never work on houses in our road.
Same problem for me... From Italy...
