Hi. Yes there should be sound with video because its essentially acting as a video camera when in movie/video mode. If you can see a small hole on the front of the camera facing the same direction as the lense, that would be the microphone. Sometimes it even says "mic" at the hole or even may show a picture of a microphone.
Testimonial: "It was helpful and has sort of helped me with my problem! "
SOURCE: can't hear audio on video playback (neither direct from camera nor from pc)
This is because the camera is not capable to record the sound. The camera was not designed with any audio speakers to be able to record and playback sound recorded during movie mode.
SOURCE: Cybershot dsc-w70 stuck in video mode
Ok! I've searched and searched, so hopefully this will help you all out.
If the videos are very slow moving, you're in multi burst mode. Simple fix, actually...
Press menu button that's below the dial selector. There should be two small options near the bottom of the screen "mode" and the little suitcase.
Go into mode and make sure that Normal is selected. Multi Burst is actually a 16 frame per second function good for sports. It shows as a slow motion video on the camera and a sort of collage on your computer.
Hope this helps. :)
SOURCE: the sound on my camera doesnt work and i dont know how to set it?
some digital cameras have sound when u make a video some not,.....read ur Manuel and it will tell u if u have sound or not.....
SOURCE: Just bought a Nikon Coolpix S8100. After
You will need to install a codec pack on your computer to resolve this problem. Download and install the codec pack from the link below and see if it resolves the issue.
http://www.free-codecs.com/download/k_lite_mega_codec_pack.htm
Then why when I record a video and play it back on the camera there isnt any sound?
Are you using the correct cable to go from camera to your tv? One with audio jacks as well as video? Most cables have the mini usb on the camera end and a red/white and yellow RCA jack on the other end to hook up to a tv. If it goes to a computer the cable should look like a mini usb and a regular usb on the other end.
