Fuji FinePix A700 Digital Camera Logo
Question about Fuji FinePix A700 Digital Camera
Hi I erased my xd card, then I couldn't take any more photos because it kept saying memory full, so I bought a new2gb olympus xd card with new batteries, camera still saying memory full. Any sugge
Yes a Fuji FinePix A700 Digital camera
Pcrepair Dublin
    New Friend:
  • 11 Answers
Is it a full restore? or a factory restore if so, live the card in the camera and do it then.
Posted on Jul 27, 2012
  • Anonymous Jul 27, 2012
    Hi there, all ok now, thanks for the help.
4 Related Answers
Anonymous
  • 423 Answers
SOURCE: Fuji Finepix xd Card.
1) use the format option to get the card ready for your camera.
2) If that fails, the camera may need to go to Fuji for a firmware upgrade (assuming your new card is type H or M card). I don't believe the upgrade is performable by the user.
Posted on May 26, 2008
Anonymous
SOURCE: New memory card
Hi I have bought a new memory card, Olympus XD M 1GB. For my Fuji fine pix A330 camera, and I can't get it to initialise, or format properly, can you help me many thanks TRENA
Posted on Sep 28, 2008
Anonymous
SOURCE: cannot see picturs from memory card
The pictures were stored on the camera and not the memory card.
Issue resolved.
Posted on Apr 15, 2009
jonniewalker
Starnley Johnwells
  • 1031 Answers
SOURCE: How to initialize totally erased memory card.
initialise(format)
  1. press < or > to sellcet ok
  2. pressing the MENU/OK button erases all the frames(files) and initialises the picture card
Posted on Oct 21, 2009
My Olympus c-740 tells me there are no photos, although the memory is full. It says it is full in the camera and in the computer. I need the photos, no the memory. Thanks!
There is memory built into the camera and additional memory card! Depends how the camera is set to save the photos either to the smaller built in memory or the larger memory card!
2answers
Card 'full' but no files found...olympus 1040
hi, there's a problem in your memory card and you need to do first is format the memory card into camera (if its ok to you to delete all the picture save in memory card). If the problem still occur you need to buy new memory card.
thank you and good luck my friend
2helpful
My xd memory card full of photos produces error
Yes you can, download a software to recover the photos inside your memory card. It is know as memory card recovery tool, search that in the internet.
I just bought an Olympus mju 820 and it keeps telling me that the memory card is full but i have only taken 4 photos. I have put in the xD picture card and it still won't allow me to take any more photos....
try to change the mega pixel rating and see,,,,
did you format the memory card initially before using that brand new??
also see if the storage is set to memory card and not to the main memory
Xd memory card
A card access error may indicate that an xD-Picture Card memory card is in a write-protected condition. xD-Picture Card memory cards have a special protection feature to ensure that your pictures are kept safe. NOTE: During this condition, you can still use the printer for printing and saving photos from the xD-Picture Card to a secure location, such as the computer hard drive. To resolve this error, try the following:
  • Reinsert the xD-Picture Card memory card into your camera and turn on the camera. In most cases, the camera automatically makes the necessary changes.
  • Reformat the xD-Picture Card memory card. See the documentation that came with your camera for instructions on reformatting the memory card. Note that this process erases the pictures currently saved to your memory card. To save these pictures, transfer them to the computer before reformatting the memory card. Once you reformat the memory card, transfer those photos back to the memory card using the computer.
2helpful
When i turn my digital camera on with the memory card in it (XD M256mb) it says the card is full. I go to erase photos and it says there are no photos to erase. If i take the memory card out, i can take 15...
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Ok button - right arrow to Mode Menu - down arrow to Card tab - right arrow to card setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the card full message and the card can be used again.
2helpful
New memory card
Olympus SP-320 memory full when 1GB xD picure card in camara
If you download the photos that are on the internal memory to your computer, the next time you take photos it should go to the memory card that is loaded. It worked for me, so I hope that helps
1helpful
4answers
Screen reading memory card not initialized
I bought a new memory card for my finepix A330 camera When I turned on the camera after putting in the new card, the screen read "card not initialized" and won't take photos.my son is going holidays 13/9/08 could you help me please Alex Richardson
No Image
Please read these/the 2 posts that I posted prior for a similar XD mem card problem, as I firmly believe you are "formatting" your mem card improperly using your home computer instead of "formatting" the card on your camera.
Also the XD type card & size are very important also!!
What you will have to do is read and download the photos you have on that XD card using the same "card reader" you used before and then properly "re-format" that card in your "CAMERA ONLY". This should solve your XD card problems.
PRIOR POSTS:
Kristina,
Not knowing what model Olympus camera you have, or how old it is - your new memory card "format" problem is one of 3 possibilities.
1st - If you have an older Olympus camera more then 4-5 years old the newer M & H series type cards over 256mb will probably not work in your older camera, as by the camera's internal firmware chip design of the camera itself. Some cameras were upgradeable some weren't as to the internal firmware chip as well as available software drivers depending on which computer OS system you were using ie: (WIN98SE, WIN2000, etc). Has to do with the memory card read/write chip speed as well, and also has to do with the physical storage size of the card itself. Some digital cameras were MAXED OUT at 512mb cards, some as low as 256mb. A 2gb card simple won't work in that/your camera in that case.
If you read the camera's user manual it will possibly tell you this, or else go online to www.olympusamerica.com and use this link:
View which cameras are compatible
Select camera model series and scroll down the model # and research the max card size & type you can use (3 basic XD card speed types available - regular XD - M type - H type).
If you are using the wrong type & size card you will need to return that card (if you can) and get the right XD size & type for your camera.
2nd - You should always FORMAT (same as ERASE ALL and FORMAT modes on most Olympus cameras) the new card, or any XD card for that matter in your camera itself. NOT THE HOME COMPUTER!!! The 2 format procedures are not the same!!
If you are re-shooting (re-using) the same XD card over and over again and then downloading the JPEG pix directly to the computer using a USB interface cable there usually is no need to re-format the card again as long as the XD card stays the camera and is not downloaded into a home computer via a "card reader". If you do the latter "card reader" then I would advise doing a card re-format in the camera again just to be safe!!
And lastly - If your home computer recognizes the XD card via a good "card reader" (do not FORMAT the XD card here btw, as you are just checking the card out to see it is GOOD is all), but the camera will not then that is a good sign your camera is OK, but it's just the wrong type & size XD card.
Hope this helps solve your camera XD problem not knowing which model you have.
Best regards,
Frank
AND:
Follow up to previous post:
I didn't have the time to access the exact link below to check on your specific 2004 model year camera because I missed the Fuji camera model part, as I'm brand new to this site - so please forgive my previous oversight here.
I was right though in my initial posted assumption that you bought the wrong XD memory card based on your Fuji FinePix A330 Digital Camera - as to it's older model year - in that your camera is limited to a 512mb memory card.
Make sure you buy the 512mb standard card if you still can find them. Otherwise check with Fuji Corp to make sure the M type card (faster read/write chip) will work in your specific model. The M type cards work just fine in my Olympus C-740 even though it was told to me they wouldn't work at all, but each digital camera is slightly different as to it's internal firmware (BIOS) chip.
See the following camera info for your specific model at the link below under Storage Media:
Steves Digicams - Fujifilm FinePix A330 - User Review
I hope this now clears up any prior confusion from the previous post.
Best regards,
Frank
Top Fuji Cameras Experts
Steven Wander
Steven Wander
David Shaub
Steve
Are you a Fuji Camera Expert? Answer questions, earn points and help others
