Televison & Video Logo
Question about Sanyo AVM-2506 TV
Power supply sanyo model:avm-20hc for trouble
4 Related Answers
Anonymous
  • 346 Answers
SOURCE: schematic for a sanyo avm 2506 tv
www.samswebsite.com
Posted on Mar 18, 2008
Anonymous
  • 644 Answers
SOURCE: where is the 470mfd filter cap on a sanyo avm 2053. what circuit
It should be on the main power board, near where the power cord plugs into the set. It will be quite a large cap, you can check its value by reading the value on the side of it, ensure the you replace it with the same value cap.
Posted on Feb 17, 2010
Anonymous
  • 321 Answers
SOURCE: I have a SANYO model # AVM 3659G, Wont come back on
Hi, that probly a power supply plroblem, or a high voltage regulator and the horizontal transistor that drive the high voltage transformer at a high frequency (15.000 hz )if you think you can trouble shoot that ok; if not ask a friend who you no he nows about trouble shooting in tv. or you can go to a repai r shop should not cost to high half hour + parts
Beware high voltage in there(30 thousand volts
hope that help you
Posted on Mar 13, 2010
Anonymous
  • 17 Answers
SOURCE: Loud buzzing sound on Sanyo AVM 1909
I had a problem like that so I disabled the tv's onboard tuner (input source)and now we use the cablebox's video and audio out to the video and video in jacks on the TV this will work as long as you have a cable box or sat reciever for your video and audio source and of course your TV must have video and audio inputs so it will work.
Good luck Rich
Posted on Jun 06, 2010
1helpful
Schematic diagram for sanyo tv AVM-2979P
Only two choices here aside from Google the model number with "service manual" is to contact Sanyo or look to see if the set is covered by a Howard W. Sams photofact manual.
hope that help you
Where is the 470mfd filter cap on a sanyo avm 2053. what circuit
SANYO MODEL#3659G TV 36"
Thomas,
How did you check the fuse? Just by looking at it or do you have a multimeter?
If you have a meter check the secondary diodes on the power supply and the horizontal output transistor. Perhaps one of them is shorted.
Tv in video mode
sanyo model: AVM-21 MB
problem: during tv mode the reception will loss and back
in turn to blue color then back to channel frequency!
at video the picture is okay but ther is no audio!
can you please suggest me how to solve this problem
can you send this to my email add.
albertdlc_12yahoo.com thank you and more power!
TV sounds like power up for few seconds then goes off
You have a short somewhere causing the power supply not to start. Most likely a shorted horizontal output transistor and maybe a flyback transformer which caused the transistor to short. It would have to be checked out by a technician to find out exactly happened. Stargazer
No picture,no sound,blank
This set is very popular for the capacitors to dry upa and go bad in the main SMPS as well as the switching power supply. If you have no know how on how to test capacitors or solid state electronics please take the set into a repair shop for an estimate
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
