There are 4 bolt holes on top of the speakers and 4 on the bottem where U shape brakets attach to mount the speakers to the wall. Are the top bolt nut plates capable of supporting the weight of the speakers or will they pull out? I would like to know how these speakers can be flown from the ceiling.
SOURCE: dont know what size bolts
you should use minimum of 1/4" lag bolts by 2'" long.
Find a wall stud, and drive the bolts(one above the other into the wall through the mounting bracket holes.
SOURCE: Weight of TV...in order to select proper wall/ceiling mount
Quick solution:
Weigh yourself on a scale. If you can, pick up the TV and step on the scale again. The difference between the two readings is the weight of your TV.
SOURCE: I need to buy one Wharfdale Modus 8 speaker only.
I have two modus 8 speakers in great condition wanting to sell will be inexpensive if you are interested please email [email protected]
SOURCE: I've built a 2x12 guitar speaker cabinet with a
Do you want to know how I fixed my problem? I asked someone who wasn't a complete A-hole, thats how! They told me how to fix it without giving me the run around like Fixya did! Having me spend time typing out and submitting my question only to tell me..." Oh yeah, we might be able to help, or maybe not. Just pay us first and we'll let you know." You guys are a joke! Why doesn't Fixya answer the first question, so people would know if they even have the ability. Yeah, whatever. So, SeeYa FixYa adioss over and out blowholes!!!!!!!!!!!!!!!!!!!!!!
SOURCE: Can't get face plate off of MTX 610CM ceiling speakers
Its a pain, espicially if the grills were painted before installation.
In the industry we use a "grill puller" which is nothing more then a wire hook with a loop for your finger.
If the holes are big enough bend a paperclip into a hook, grab it with needle nose pliars and pull the grill through the hole near the edge.
If it doesn't fit then use a small pointed knife or awl, stick the point in a grill hole around the egde and pull it down a bit, work your way around until you can grab the grill with your fingers.
Let me know if you need anymore guidance......be careful I've replaced alot of destroyed speakers!
Cheers,
Kevin
Testimonial: "Yes that worked great!!! Thank you!"
