Sunpak Auto 221d Flash - For Canon Film Cameras Logo
Question about Sunpak Auto 221d Flash - For Canon Film Cameras
Can I use the Sunpak auto 221d dedicated for minolta on a canon dslr?
It's an old flash my dad had and I want to use it on my new T3i. Is this safe?
Posted by Chris A on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sunpak Master
  • 102,366 Answers
No. The flash's trigger voltage is much too high. You could use something like this to isolate the units, however you won't get any of the automatic functions.
Posted on Jul 27, 2012
5 Related Answers
Anonymous
SOURCE: sunpak pz 4000 af
probably in MANUAL mode only.... my Nikon and Canon's work with the pz4000 (at a save trip voltage I may add) but in a manual mode as mentioned above.....
Posted on Apr 19, 2008
Anonymous
SOURCE: sunpak pz 4000af for minolta
The Alpha 100 only supports pre-flash TTL and ADI flash control which are not supported by the Sunpak. The flash should ignite, but automatic controlling of its brightness is not possible.
For more Information about the different Minolta/Sony Flash Metering modes cf. http://www.mhohner.de/sony-minolta/flashcomp_mm.php
Posted on Jan 09, 2009
Anonymous
  • 188 Answers
SOURCE: Sunpak 344D Pentax K20D dedication
Seems like you may be ok. Google pentax k20d supak 344d compatability.
Posted on Jul 19, 2009
Anonymous
  • 1187 Answers
SOURCE: can I use sunpak 1600a flash (older) with Pentax
Yes, it's possible.
The flash sensor is calibrated for a 35mm optics & iso (asa).
You may have to "UP" your digital camera's iso sensitivity to 800 or so.
You will have to experiment with it at various settings.
Try using the "bracket" sewtting on the camera.
It takes three pictures when you press the shutter button; the three have different "values" of brightness.
The bracket setting is on the UP arrow, where you can choose "single frame", "continuous frame", bracket, etc.
Hope this helps!
Posted on Sep 14, 2009
Anonymous
SOURCE: I have a Sunpak PZ42X for Canon and a Canon T1i.
I have the same problem and i dont have a idea to solve it. Did you do something?
Posted on Feb 26, 2010
I have a Sunpak pf30x flash (ETTL II for Canon) and a 550d Canon but the flash will not work. the flash works on my Canon Eos 300 film. Help
Many flashguns deigned for film cameras - even really expensive ones - will not work with DSLRs.
I have a perfectly good pentax gun that cost me almost £300. It is fanstastic on my TOTR Pentax SLR but will only blat at maximum power on my Pentax DSLR. I had to spend another almost £300 to buy the new gun that will work with all the bells and whistles on my DSLR.
It looks as though Canon work theirs the same way.
I have sunpak pf30x fash unit for canon camera.but i need to use it for nikon D90.how can i do it? is ther any converter units or hot shoe unit
No. The PF30X is a dedicated unit, specifically for the particular brand of camera. A Canon unit, such as the one you have, will not work in auto mode on a Nikon camera.
3helpful
Hi. Will a Vivitar 550FD flash unit work properly with a Nikon D5000 digital camera without doing damage to the camera? Thanks,Arty
The 550 FD came out before digitals. It is fully dedicated(FD) to a type of film camera. Usually this is noted on the back of the flash. CA or C for Canon, MI or MX for Minolta, Ne or NI for Nikon. If its the Nikon dedicated unit, it should not harm your camera, and will most likely work...as a manual flash. You will lose all the neat flash stuff that the D5000 can do.
I suggest you watch Ebay for a Sunpak PZ-30, PZ-40, or a Sigma 430 or 500. The Sigma EF 500 Super will do pretty much everything the top of the line Nikon Flash does, but you can buy it new for half the price of the Nikon unit. All flashes today are dedicated to a certain group of cameras by a certain manufacturer. For example: Canon EOS film cameras or Minolta manual focus cameras.
I suggest you get rid of the 550FD as it is designed for the pre-Autofocus cameras.
Avoid the Sunpak Auto 30DX, the 333, 383, 433, 444 and the PZ 4000/5000 as well as the MZ flashes. These were not designed for your new digital.
Metz also makes some very nice flashes, but they're kinda pricey.
Dec 30, 2009 • Cameras
3helpful
I have a sunpak 622
Sunpak does not offer dedicated (TTL) module to any digital cameras. The flash can only be used in auto mode, while the camera is set to full manual. The lens has to be stopped down according the working aperture on the flash, correct exposure will be maintained by the built-in sensor of the flash. Fire the flash using a simple hotshoe-to-PC cube if your camera doesn't sport a PC connector. Trigger voltage of the 622 is safe.
4helpful
Canon I use the Canon XTi and sunpak 544
The Rebel XTi has a sophisticated communication protocol between the camera and a dedicated flash. Only ETTL-II capable flashes can benefit from all the features the engineers at Canon thougt out. This means that with the otherwise superb Sunpak you won't be able to emit autofocus assist pulses, red-eye reduction pulses, the camera won't increase or reduce the flash intensity for bracketing, zoom lens settings won't be reflecting on the flash illumination angle, and so on. But! Set your Canon to full manual (125th sec), set Sunpak to auto, take one of the working apertures according to your taste (depth of field, etc.) and set the same aperture on the camera, and shoot. You still can use bounce flash. I am not sure about second curtain flash, I suspect it won't be possible. Both tele kit and milky filter in front of the flash head are of great help, you don't need to worry about the differences these make in flash intensity. Always keep in mind that the flash makes good exposure according to the given working aperture and, as long as you set the same aperture on the camera, the subject will be correctly illuminated. (I have a Sunpak 522 and a 455 and employ them this way, with success, on my XSi.) Of course you can set set the flash in full manual (M/PR/MD), using the left side, set knob and calculator dial, and this is the only way if you want to make series of shots, because the flash can only make bursts if the power is reduced to at least 1/16th. Good light, Laszlo
2helpful
5answers
Sunpak Auto zoom 3000 thyristor
You can use the Sunpak on a bracket with a "slave trigger" and fire the slave with the Nikon's pop-up flash. I do the same with a SunPak 3600 Auto Zoom. Just remember not to have the red-eye feature operating. Those little slave triggers are only a couple of dollars and I already had few brackets.
Jun 03, 2008 • Cameras
Flash
becRN,
take the camera to a good camera store and try any in your price range, the manual should state the camera's that are compatible. note that many new model flashes do not work on older camera's.
Sunpak pz 4000 af
2helpful
Sunpak pz 4000af for minolta
Top Sunpak Cameras Experts
ADMIN Andrew
ADMIN Andrew
Tom Chichester
Are you a Sunpak Camera Expert? Answer questions, earn points and help others
