Question about Minolta C350 Color Printer/Scanner/Copier
Ko0nica minolta c350 blad c0016 - Minolta C350 Color Printer/Scanner/Copier
Norman J Weimar Jr
  • Minolta Master
  • 6,960 Answers
Pull out the black image unit shake the image unit side to side you are going to try to spread the developer and toner inside the image unit along the entire length of the image unit, I bet the image unit was stored standing up and the person just plug it in with all the developer sitting at one end the motor that turns the drum had a hell of time trying to turn always store image units laying down always before placing them inside the machine shake the image unit to spread the developer along the image unit, if this does not work get a new image unit or the motor is burned out worse case control board for the motor is bad$$$$$$$$$$$$$$. Open close front door to reset
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Feb 15, 2015
1 Related Answer
firecontrol7
Norman J Weimar Jr
  • 6960 Answers
SOURCE: Konica Minolta C350 colour copier T096 error code??
Transfer belt code C096 mite try open and closing the front door where you put the toner. Also remove the image transfer belt and then reseat it.
Posted on Jul 19, 2009
Error code c0016
Sir/Mam,
The Black Image unit remove it and reseat it inside the machine properly WAS the Black Image Unit New was it store Vertical instead of Horizontial. If so all of the developer is sitting at one end of the image unit instead of being spread out along the length of the image unit that Black Drum motor can't take all of the developer sitting at one end., Ensure all of your image units are stored flat not up and down. Ensure you also shake the image units before installing to spread the developer (Side to side). Then close the door and should go ready to copy if not and it comes back then bad motor or board
C350 driver
To offical konicaminolta website drivers are free.
Konica c350 c0016
Sir/ Mam Your Black PC Drum Motor is failing to turn. 1. open close front door to reset. If that does not work remove the black image unit and shack it side to side we want the developer inside the I/u to spread out along the entire length of the I/u not all sitting at one end of I/u that make the motor have a difficult time trying to turn. All I/u boxes should be stored horiz. not vertical.
C0016 retraction
Black Image unit Motor failure to turn. Remove the black image unit then shake side to side. what you want to do is spread the developer (Located inside the unit) along the entire length of the image unit. BET the image unit was stored up instead of flat, person just picked it up and installed it. All the developer was sitting at one end so the motor could not turn correctly. NEVER EVER STORE I/U UP always Flat!!!. Open & close front door to reset. If it comes back then you might have already burn out the motor, worse case the Control board went bad.
6helpful
3answers
Konica minolta bizhub c350 error codes c-0510
eror code c-0098 meaning ??????????????pls tell me the solution
1helpful
2answers
Konica minolta bizhub c350 installer for mac
You have to have a fiery unit (external controler) to use the C350 With a Mac because the c350 dosnt come with appletalk in the software. IC-401 Is the model number of the controller you will need to connect the c350 to any kind of mac for printing / scanning.
4helpful
The printer is a Konika Minolta cf2002 DIALTA Colour, after initialising, the printer gives error code c0016 and 31C-M if the printer reports ready, when you sent a document it does not rpint, instead it...
The C0016 code means that the Black Imagine Unit's Motor is not turning. So you will need to check all the connections and connectors on the black imaging unit and try re-installing. You could replace it if you have a spare.
The 31C-M code is not in my service manual and I have never seen that code before.
C350 is printing is not clearly other color is over lap and shade
Clean the LED assy with the jig that you have inside the front cover.
I can't print from IMac to konica-minolta buzhub C350
Go to konicaminolta web site and download a mac driver. and install it to Imac. Make sure to download OS10.4 or higher.
Open Questions:
See all Minolta C350 Color Printer/Scanner/Copier Questions
Top Minolta Office Equipment & Supplies Experts
Daniel Blask
Daniel Blask
Muzahura Frank
Mehandi Husain ...
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
