Question about RIM BlackBerry? Curve 8330 Cellular Phone
Will unlocking my verizon bb 8330 with jvm error 102 fix this phone
I have jvm error 102 on my verizon blackberry. if i unlock this phone and use a sim will it fix this
  • 118 Answers
Codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Posted on Jul 27, 2012
3 Suggested Answers
koronotoaja
  • 1487 Answers
SOURCE: need to unlock bb curve verizon so i can use it through metro pcs.
To unlock blackberry curve from verizon network you will be need a blackberry unlock code. With that code your phone will accept any sim card network for any provider so you can use your metropcs sim card in your phone.
Posted on Oct 25, 2011
vilasdesh
SOURCE: i have a blackberry 8330
i have a blackberry 8330 when i put on the phone . theres a white screen that says jvm error 102 reset
Posted on Feb 02, 2011
khan khalail
  • 101 Answers
SOURCE: my blackberry 8330 has a jvm error 102 code, how
you can get this Blackberry imei unlock code from your network provider or get from third party,
both are safe way to Unlock your Blackberry 8330 .when you go to online you can find so many sites of Blackberry imei Unlock Code. they will charge little amount for your Blackberry Unlocking Codes. i hope this will help you:)
Best of Luck.
Posted on Feb 11, 2012
Hi I haven't used my phone for a couple of years. when I switch it on now it say.. error 102 reload software... what do I do?
You need to do a Factory Reset, AKA a Hard Reset. This removes everything on the phone and reloads the operating system. Your phone is a Blackberry?
  • Error 102 Reload Software - BlackBerry Support Community ... https://supportforums.blackberry.com/t5/BlackBerry-Device-software/... Hello, I've just had a problem with my Blackberry 9930 phone. I already tried updating the Blackberry Desktop Software and I also tried the phone,
  • Error 102 - Reload Software - Blackberry Torch 981 ... https://supportforums.blackberry.com/t5/BlackBerry-OS-Smartphones/... Hi. I took the battery out of my phone and when the phone re-booted I now can only see a white screen with the error 102 and states reload software.
  • How to Reload Blackberry Mobile Software - Snapguide snapguide.com > Technology > Explore
    • 3.5/5
    • 10 RATINGS
    • BY TAHANI ALGHAREEB
    i will teach you how to reload your blackberry soft ware when its got error 102 and not working by this steps. all you ... How to Reload Blackberry Mobile Software
  • JVM Error 102 on your BlackBerry? Try this solution BEFORE ... crackberry.com > ... > Classic > Z30 > Z10 > Q10 > Leap > OS 10.3.2 Video embedded · JVM Error 102 on your BlackBerry? Try this solution ... JVM Error 102 on your BlackBerry? Try this solution BEFORE wiping! ... "Error 102. Reload Software ...
  • Terpecahkan: Curve 9360 Error 102 (Reload software ... forumdukungan.blackberry.com/...Error-102-Reload-software/td-p/258111 Terpecahkan: Dear all, Saya newbie disini, BB saya curve 9360, sudah mati 5 hari dengan error 102 (reload software). Sudah coba ikut instruksi dari
  • How to fix an error 102 reload software blackberry torch ... www.askmefast.com > ... > Error How to fix an error 102 reload software blackberry torch 9810? ... How can I fix reload error 102 on blackberry torch 9810? Comment. Reply. Report.
  • ERROR 102 www.blackberryos.com/general-blackberry-issues/38452-error-102-a.html
    • 2 POSTS
    • FIRST POST: 2013-08-12
    2013-08-12 · how do i reload software on a bb 9360?? ... Join Date Dec 2010 Location Gainesville, FL PIN Jarmeling Device Passport OS 10.3.2.2134
  • May 20, 2016 | Cell Phones
    My blackberry 8330 has a jvm error 102 code, how do i fix it? also has plain white screen and will not do anything else.
    Best of Luck.
    Nov 06, 2011 | RIM BlackBerry? Curve 8330 Cellular Phone
    I have an old bb storm unlocked from Vodafone and im having trouble viewing videos i have recorded from the phone
    You need to upgrade your blackberry software, since even your blackberry unlocked that software configuration still using default setting from your old network provider. Some phones have other problem after unlocked like browser stuck, death microphone etc. In this case your blackberry curve 8330 unlock code for verizon is working but you need some a little job to fix up your software. Like i said before that is a general trouble that may happened when we put blackberry unlock code at the wrong sequence.
    Jul 05, 2011 | RIM BlackBerry? Curve 8330 Cellular Phone
    I have a blackberry 8330 when i put on the phone . theres a white screen that says jvm error 102 reset
    Dec 27, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
    My blackberry keep say jvm error 102 reset
    To resolve your problem, connect the handheld to the desktop computer and start the Application Loader.
    Re-install the BlackBerry Handheld software.
    If you don't have the software, go here: http://www.blackberry.com/btsc
    Select downloads, then BlackBerry® Device Software and BlackBerry® Desktop Software. Follow the steps from there and you should be ok.
    Dec 25, 2010 | Verizon Communications BlackBerry Pearl...
    I put in a password incorrect on my blackberry 8330 and it did a security wipe, but i took my battery out before it did.. And now it wont come on and it keeps sayin jvm error 513. How do i fix this?
    Don't worry,You can get the Blackberry 8330 model mobile unlock from security lock using the Security Unlock Code,you can get the Security Unlock code for Your Blackberry Mobile here
    http://www.onlinegsmunlock.com/blackberry-unlocking-service-b/rs7wp10/
    Nov 09, 2010 | Cell Phones
    My blackberry pearl keeps giving me the jvm error 102 and won't reset. How do I fix this?
    You can fix this by hooking up to computer and reloading the software using the BB desktop manager software, will usually also auto backup your data before it writes software.
    Jul 01, 2010 | Verizon Communications BlackBerry Pearl...
    How do i solve the jvm error 102 on my blackberry storm
    Your Blackberry probably just needs a firmware restore. Here's a guide on how to restore the blackberry firmware, the website is at : Restore Blackberry 9530.
    May 15, 2010 | RIM BlackBerry Storm 9530 Smartphone
    Jvm error 513 on blackberry, how can i fix it?
    This link say its for an error 102 but follow the steps the same way and you should be able to fix your phone.
    http://forums.pinstack.com/f23/jvm_error_102_step_by_step_fix-10781/
    Feb 24, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
    How to reset if JVM error 102 is hown on the
    Try to replace the firmware / system software of your BlackBerry Boild 9700 to fix your initialization errors. The latest BlackBerry Bold 9700 system software is available through here.
    Jan 21, 2010 | RIM BlackBerry Bold 9700 Smartphone
    RIM BlackBerry? Curve 8330 Cellular Phone Logo
    133 people viewed this question
    Top RIM Cell Phones Experts
    RONALD CARTER JR
    Ekse
    William Norris
    William Norris
    Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
