The copier used to print LTR even when we put a small size paper for example ID without it asking us what size paper to choose. I accidentally change the settings to Auto paper select and every time we put a small size it would ask us to choose paper size. Thanks
You can program the copier to just print from the letter tray by choosing the letter cassette on the display and then immediately hit the additional functions key....select copy settings and scroll through until you see the store current settings option which will make it default to the letter cassette every time. Try to do an internet search for the ir2200 operators manual. A lot of the time the book is available for free download and the customer settings are outlined in great detail in that book. Good luck.
Testimonial: "Thanks"
It doesn't have the option to store copy setting
I beg to differ......let me try to be clearer with the answer.....call up the desired screen by hitting additional functions---copy settings---standard settings-----then select store (not initialize). Remember to first select the letter tray under paper select before you go into add functions to store the setting. Hope this helps.
Sorry Robert, I accidentally pushed the wrong button the first time. haha Thank you very much. It works.
Do you by any change know how to set the copy ratio from letter size to legal size? The only options we have is lgl-ltr, 11x17 to ltr or stmt, 25% min, 800% ma, 400%, 200% to stmt or 11x17, 129% ltr-11x17 and 121% lgl - 11x17. Thanks
oops chance
all I could suggest is that you play with reduce / enlarge . The copier will let you adjust in 1 percent increments if no standard setting gives you the result you want. Look for the zoom keys.
