Question about Samsung C3050 Cell Phone
How do i install applications - Samsung C3050 Cell Phone
Posted by Hassan Maqsood on
Expert
  • 118 Answers
  1. Click Start where it says Add / Remove Applications.
  2. Type your password, if prompted, and click OK.
  3. In the Device Application Selection screen, click Browse. Go to the directory of the application you want to add, select the <application>.alx file, and click Open.
  4. Once the application is in the Device Application Selection list, verify it is selected, and click Next.
  5. On the Completing the Application Loader screen, verify the software to install is listed under Applications to be Installed or Updated, and click Finish.
If you are using BlackBerry Desktop Manager version 4.0 to 4.3then you need to follow this steps:
  1. Connect the BlackBerry smartphone to the computer.
  2. In BlackBerry Desktop Manager, open the application loader tool.
  3. In the Application Loader Wizard, click Next.
  4. Type your password, if prompted, and click Next.
  5. In the Handheld Application Selection screen, click Add. Go to the directory of the application you want to add, select the <application>.alx file, and click Open.
  6. Once the application is in the Handheld Application Selection list, verify it is selected, and click Next.
  7. On the Completing the Application Loader screen, verify the software to install is listed under Applications to be Installed or Updated, and click Finish.
  8. Once the application is installed on the BlackBerry smartphone, click Close in the Application Loader Wizard.
Posted on Jul 26, 2012
I want to disconnect/remove an external GE water filter for a refrigerator from the copper lines that go in and out of the filter. They were pushed in place to install, but how do I get them out?
Install applicationsYou can transfer installation files to your device from a compatible computer,download them during browsing, or receive them in a multimedia message, as anOther applications© 2010 Nokia. All rights reserved.106
e-mail attachment, or using other connectivity methods, such as Bluetoothconnectivity.
You can use Nokia Application Installer in Nokia Ovi Suite to install an applicationto your device.
Icons in Application manager indicate the following:SIS or SISX applicationJava applicationwidgetsapplication installed on the memory cardImportant:Only install and use applications and other software from trustedsources, such as applications that are Symbian Signed or have passed the JavaVerified™ testing.
Before installation, note the following:
? To view the application type, version number, and the supplier or manufacturerof the application, selectOptions>View details.
To view the security certificate details of the application, selectDetails:>Certificates:>View details. Control the use of digital certificates in Certificatemanagement.? If you install a file that contains an update or repair to an existing application,you can only restore the original application if you have the original installationfile or a full backup copy of the removed software package. To restore the originalapplication, remove the application, and install the application again from theoriginal installation file or the backup copy.
The JAR file is required for installing Java applications. If it is missing, the devicemay ask you to download it. If there is no access point defined for the application,you are asked to select one.Other applications© 2010 Nokia. All rights reserved.107
To install an application, do the following:
1. To locate an installation file, selectMenu>SettingsandApplication mgr..Alternatively, search installation files using File manager, or selectMessaging>Inbox, and open a message that contains an installation file.2. In Application manager, selectOptions>Install. In other applications, selectthe installation file to start the installation.
During installation, the device shows information about the progress of theinstallation. If you install an application without a digital signature orcertification, the device displays a warning. Continue installation only if you aresure of the origin and contents of the application.To start an installed application, locate the application in the menu, and select theapplication. If the application does not have a default folder defined, it is installedin the Installed apps. folder in the main menu.
To see which software packages are installed or removed and when, selectOptions>View log.Important:Your device can only support one antivirus application. Havingmore than one application with antivirus functionality could affect performanceand operation or cause the device to stop functioning.
After you install applications to a compatible memory card, installation files(.sis, .sisx) remain in the device memory. The files may use large amounts of memoryand prevent you from storing other files. To maintain sufficient memory, use NokiaOvi Suite to back up installation files to a compatible PC, then use the file managerto remove the installation files from the device memory. If the .sis file is a messageattachment, delete the message from the Messaging inbox.
May 07, 2018 | GE Refrigerators
Tip
Load applications onto your blackberry.
<span> <p>To load applications onto your BlackBerry, you need to work closely with your PC. On your PC, you use an <span>application</span> called <span>blackberry desktop</span><i> Manager</i> (BDM), which comes on a CD along with your BlackBerry. Application Loader is a mini application within BlackBerry Desktop Manager.If you have an employer-issued BlackBerry, your company might impose guidelines on what applications (if any) can and cannot be installed and uninstalled from your device. Be sure to familiarize yourself with your IT department's policy before attempting to install or uninstall software from a company-owned BlackBerry.<span>Accessing the Blackberry Application Loader</span>After BlackBerry Desktop Manager is installed on your PC, do the following to access Application Loader:<span>1. On your PC, select Start --&gt; Programs --&gt; BlackBerry --&gt; Desktop Manager.</span>BlackBerry Desktop Manager opens.<span>2. Connect your BlackBerry to your PC via your USB cable.</span>Doing so connects your BlackBerry to your PC. If successful, you see the password dialog box. If not, check to see whether the USB cable is connected properly to both your PC and your BlackBerry and then try again. If all else fails, contact your service provider, or contact your system administrator if you're an enterprise user.<span>3. Enter your password.</span>This completes your BlackBerry-to-PC connection.<span>4. On your PC, double-click the Application Loader icon in BlackBerry Desktop Manager.</span>The Application Loader Wizard welcome screen opens. At this point, you're ready to use the functions of Application Loader.<span>Using the Blackberry Application Loader</span><br /> <p> <span><span><span> <br /> <span> <p>To install an application onto your BlackBerry from your PC by using Application Loader, you first have to install that application onto your PC. The installation onto your PC varies, depending on which application you choose to install, so be sure to refer to the manual that comes with the application you choose.After you get the application onto your PC, you need to locate the application's ALX file (a file with the .alx extension). The ALX file isn't the file that gets installed on your BlackBerry; rather, it tells Application Loader where the actual application file is located on your PC. You can usually find an application's ALX file in the folder where you installed the application on your PC.you can install it on your BlackBerry by using Application Loader as follows:<span>1. Launch Application Loader from BlackBerry Desktop Manager.</span><br /> <p>The Application Loader Wizard welcome screen appears.<span>2. Click the Next button.</span><span>3. Enter your password, and then click Next.</span>If your handheld isn't connected properly, you see the Communication Port Selection screen. Connect your BlackBerry to the USB cable and make sure that the USB cable is connected to the PC. Then click Next.The Handheld Application Selection screen appears. This screen lists the applications that are already installed on your BlackBerry.<span>4. Click the Add button.</span>An Open file dialog box appears, which you use to locate the ALX file of the application you want to install.<span>5. Locate the ALX file and then click Open.</span>You return to the Handheld Application Selection.<span>6. Click Next.</span>Doing so brings up the confirmation screen, listing the application to be installed.<span>7. Click Finish.</span>The installation process starts, and a progress window appears. When the progress window disappears - and if all went well - the application is on your BlackBerry<br /></span></span></span></span><br /></span>
on Nov 23, 2010 | Cell Phones
How to install game software
To download and install applications onto your Sony Ericsson Xperia X10, follow these instructions:
  1. From the Home screen, tap the applications bar.
  2. Tap Market
  3. When you open Android Market the first time, the Terms of Service window will appear. Tap Accept to continue.
  4. To search for an application, tap the Search icon, enter the search string and then tap the Search icon again.
  5. To install an application, tap the desired application and then tap Install.
  6. The applications wlll download onto your phone and automatically install.
  7. You'll then be given the option to open up the application on the Sony Ericsson Xperia X10, or close the window.
Mar 26, 2012 | Sony Ericsson XPERIA X10 Cell Phone
Applications not installing in memorycard nokia 5230
try to update your software of your mobile.
Feb 10, 2012 | Nokia 5230 Cell Phone
Phone erases text messages and call log
This happens because of large applications are installed on the BlackBerry smartphone.
To resolve this issue, complete the following steps:-
  1. Make sure that the BlackBerry Device Software is installed on the computer to display the correct total application space.
  2. Determine the application space that is available on the BlackBerry smartphone by completing the following steps.
a) Connect the BlackBerry smartphone to the computer.
b) Open the BlackBerry Desktop Manager.
c) Double-click Application Loader.
d) At the Device Application Selection screen, under the application selection window, note the total application space.
NOTE:-Select the List additional applications that are installed on the connected device check box to include the applications that are installed outside of the BlackBerry Device Software applications and the file sizes.
3) Remove applications that are not required. For example, remove additional language packs and themes.
Nov 07, 2009 | RIM BlackBerry Pearl 8100
How to install an application for my blacberry cellphone
If you would liketoinstall application using the application loader tool in the Blackberry Desktop Manager.
You should verify that the application to be installed on the BlackBerry smartphone is saved to the computer before completing the following steps.
If you are using BlackBerry Desktop Manager version 4.5 to 5.0 then you need to follow this steps:
  2. In BlackBerry Desktop Manager, click Application Loader.
  3. Click Start where it says Add / Remove Applications.
  4. Type your password, if prompted, and click OK.
  5. In the Device Application Selection screen, click Browse. Go to the directory of the application you want to add, select the <application>.alx file, and click Open.
  6. Once the application is in the Device Application Selection list, verify it is selected, and click Next.
Hope I helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 02, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Problem- installed java app got hidden
Reset ur Mobile.
They Will Work.
Jan 09, 2009 | Cell Phones
Getting error message when opening Micros Office 2003 Edition "Please run set up to install this application".
i) when you install Microsoft Office 2003 Edition some of the application will not be installed  then
there, .......when you are about use such applications  it will give an message: "Please run set up to
install this application", in such cases if you have Microsoft Office 2003 Edition CD try to put it in the CD
Tray  and installation will continue and application will installed and the problem will not persist again.
Thanking you,
M. Sridhar
Dec 26, 2008 | Gateway Computers & Internet
Application not supporting
to install any application u need to attach the phone via cable with ur phone using active sync..then run the application on the pc it will get installed automatically on the pda.
Oct 15, 2007 | HP iPAQ hw6515 Pocket PC
Samsung C3050 Cell Phone Logo
150 people viewed this question
Top Samsung Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
John Tripp
John Tripp
Ekse
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
