Dometic WA3210 Compact Refrigerator Logo
Dometic 3210 works on 12volt but not on 110 - Dometic WA3210 Compact Refrigerator
1 Related Answer
TheMobilian
Dan Webster
  • 8221 Answers
  • Posted on May 16, 2009
SOURCE: Is there a 12volt coil in a Dometic rm52 refrigator
What you would need to do is get an inverter to power the icebox. Turn the 12 volts into 110 to power up the compressor. THE INVERTER STORE has aone for $199
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dometic RM2214R refrigerator in a 1994 Layton travel trailer can't get to run on a/c power checked outside blowing the 12volt fuse?
If ur fuse keeps blowing check ur power inverter. Sounds like its throwing more than 12 at it. Does it work in lp mode?
110 volts works but 12 volt does nothing, checked voltage 13.6 v. Any suggestions. Thanks.
RV Refrigerator Stop Working? - RVing - Fun Times Guide
rv-roadtrips.thefuntimesguide.com/2009/09/rv_refrigerator.php
If your refrigerator works on gas, but won't work on electric, you may have a burned out.... Cirtis, We are camping in Montana and our dometic refrigerator decided to stop ......Won't know until you can confirm you have proper voltage to the fridge. ... If you have confirmed both 12 vdc and 110 vac power at the fridge, I would ...
[PDF]Dometic Manual Refrigerator Diagnostic Service Manual
www.nationalserroscotty.org/resources/dometic-service-manual.pdf
Dometic Manual Refrigerators. ... 110 Volt Plug. 2. .... This is Dometic's Manual Refrigeration Diagnosis and Troubleshooting program. In this ... we will discuss the way an absorption cooling unit operates, and the ... gas, 120 volts AC and 12 volts DC .....In this condition we are still boiling ammonia but have no hydrogen for.
Dometic Fridge problems - RV mechanic
Rewire 12Volt into 24Volt
You have to get you a transformer .voltage input 120 and out put 24 volts.But will have to wire it through a relay or contacter with the coil volts 24.
My dometic frig will not work no power. Has 12 volt and 110 volts
Replace the bulb and also check the relay and the sensor in the back of the unit. But first try replacing the bulb
Dometic rm2620 rv refrigerator
No you need 12vdc for the control board. If you have a convertor 110ac to 12vdc this will work for your supply instead of the battery.
Top Dometic Refrigerators Experts
Jay Finke
Jay Finke
Virgil Watts
Mike Cairns
Mike Cairns
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
