I have a Dishlex Global 500 which has recently developed a fault where the detergent dispenser fails to open. I have checked the obvious things such as it hitting the drawer but that is not the problem. Once in a while it does click but most times - nothing. Any ideas?
SOURCE: tablet drawer,dispenser wont open at all
Hi, well you we need to check the ribbon cable in the door lining to make sure that none of the cables have been broken with the movement of the door. If they are fine then you should replace the dispenser unit if you are getting 240v to the dispenser solinoid.
Get back if you have further problems...................?
SOURCE: Detergent Door not Opening
The detergent cup itself can become clogged with old dried detergent that prevents it from opening. Sometimes just cleaning the cup takes care of the problem. In case it will not solve your problem, you should replace the wax motor that operate the cup door. Good luck
SOURCE: Dishlex Global 300 Dishwasher
just bought a house with dishlex global 300
and thecycle starts and the floor becomes a river..
im guessing door seal???
but the next time i use it i gave the door an extra push to close firm and it didnt wash the flooor..
SOURCE: The detergent dispenser on my dishlex global 300
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
There are three common problems that cause the Soap Dispenser or Cup not to
open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
SOURCE: dishlex global 300 : dishwasher dispenser won't
Hi just read your posting.The problem could be a faulty dispenser coil ,or the wires to it are faulty or the computer is faulty.Try selecting a normal eco wash and when you push the start button to start the machine hold the button in until the pre wash light turns off.This should make the dispenser activate straight after it fills.The only way to test which part is faulty is with an electrical meter.Have you or can you borrow one.If so then I can guide you step by step in finding the fault.please reply with additional information and I am sure I can help you further.Looking forward to your reply.
The problem turned out to be the solenoid coil. I called out a service tech who replaced it in about ten minutes. The only damage was to the hip pocket nerve but at least the missus is happy!!!
thanks for charing this info
