Question about St Gabriel Laboratories Milky Spore Lawn Spreader Mix 20 Lb
What setting for granular milky spore
Using scotts standard broadcast spreader. what would be the best setting
1 Related Answer
Anonymous
SOURCE: I have a Scotts Speedy
I have the same question, but have not found a direct answer. I have calculated an estimate setting of 4 or 5 for the speedygreen 2000. The Milky Spore is very simular to the fertilizer that I use. Milky spore says that 1lb covers a little over 300 square feet. My fertilizer says that at a setting of 4 it is spreading 2.6 lb per 1000 square feet (almost 3 lb per 1000 sq ft or 1 lb per 333 sq ft).
Now I may be totally off, but just bought the Milky Spore today and will apply tomorrow. I may look some more tonight to see if I can find an answer. I felt it was kind of bad that the back of the Milky Spore suggested only using a drop spreader!?
Posted on Sep 13, 2010
What setting do I set my Scotts speddy green 2000 broadcast spredder to spread colonial bentgrass at 2 lbs per 1000 sq ft?
Scotts Spreaders
Robert, Normally the bag tells you the setting to use, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Scotts Spreader Settings Helper Tools Scotts
How to Calibrate Scotts Speedygreen 2000 Lawn Spreader eHow
Lawn Care Basics How To Use Lawn Spreader by Scotts
Mar 23, 2016 | Scotts Garden
I purchased my "Pro" edgeguard
The Scotts Pro Edgeguard Spreader is calibrated at the factory. This spreader cannot be calibrated, and shouldn't need to be. For further assistance, call Scotts at 877-465-5160
Hilary @ Scotts
Aug 16, 2011 | Scotts Company Scotts Pro Edgeguard...
I want to put on Scotts Grubex with an Earthway Spreader EV-N-Spread what setting do I use?
This question would best be answered by calling Scotts directly at 1-800-543-8873. One of our associates would be happy to assist you further. Hilary @ Scotts
Jul 05, 2011 | Earthway "Earthway" Medium Duty Commercial...
What setting do I use for my scotts edgeguard DLX when using lesco professional starter fertilizer 18-24-12, item#016420
If the product you are planning to apply has a spreader setting for a Scotts SpeedyGreen, or specifially for the SpeedyGreen 3000; you can use that recommendation in your Scotts EdgeGuard DLX . If they do not have a suggested spreader setting for the SpeedyGreen or SpeedyGreen 3000, then this question would best be answered by calling Scotts directly at 1-800-543-8873. One of our associates would be happy to assist you further.
May 12, 2011 | Scotts Company Scotts Pro Edgeguard...
I have a scotts standard spreader what setting should i set for using xl 2g specialty herbicide
If the product you are planning on applying has a spreader setting for a Scotts Speedy Green, or specifically for the Speedy Green 2000; you can use that recommendation in your Scotts Standard Spreader. If they do not have a suggested spreader setting for the SpeedyGreen, or SpeedyGreen 2000 settings then this question would best be answered by calling Scotts directly @ 1-800-543-8873. One of our associates would be happy to assist you further.
Feb 19, 2011 | Garden
Need the setting for a Scotts Pro edgeguard broadcast spreader for pre-emergent
Hi, W/D here.
The spreader setting instructions will be found on the back of the bag, and you will set your spreader gate opening accordingly.
Best regards, --W/D--
Feb 18, 2011 | Scotts Company Scotts Pro Edgeguard...
I have a Scotts Speedy Green 2000 rotary spreader and want to know the proper setting for your Milky Spore 20 lb. bag (granular carrier). I have been keeping it about 50% open (Setting # 9 to 9.5) but it...
Sep 06, 2010 | St Gabriel Laboratories Milky Spore Lawn...
As the cyclone brand spreader is "gone" from use, what are the equivalent settings to currently match spreading rates as listed on fertilizer bags for spreaders currently in use.
CYCLONE ROTARY
2.0
EARTHWAY ROTARY
6.0
EV-N-SPREAD
6.0
K-GRO ROTARY
.75
ORTHO ROTARY
.75
PRECISION ROTARY SB50
1.50
RED DEVIL ROTARY
1.50
REPUBLIC EZ ROATRY
.75
SCOTTS SPEEDYGREEN 1000,2000,3000
2.12
SCOTTS BASIC BROADCAST
2.12
SCOTTS EDGEGUARD BROADCAST
2.12
SEARS ROTARY
.75
TRUE TEMPER ROTARY
1.5
VIGORO ROTARY
1.50
SCOTTS STANDARD ROTARY
2.12
CRAFTSMAN
6.0
SCOTT’S EASY GREEN
25
SCOTT’S HANDYGREEN
__________________________________________
Drop Spreaders:
K-GRO DROP
2.25
ORTHO DROP
2.25
REPUBLIC EZ DROP
2.25
SCOTTS ACCUGREEN 1000
3.0
SCOTTS ACCUGREEN 2000
3.0
SCOTTS ACCUGREEN 3000
3.0
SCOTTS DROP PF1, PF2, PF3, PF4
3.0
SEARS DROP 2.25
Apr 29, 2010 | Scotts Company Scott'S& Lawn Pro Spreader...
I buy Scotts fertilizer and use an earthway broadcast spreader.
add 10 - Scotts Turfbuilder spread at # 4 on a Scotts spreader should be on setting # 14 on an Earthway spreader.
Mar 28, 2010 | Earthway "Earthway" Medium Duty Commercial...
St Gabriel Laboratories Milky Spore Lawn Spreader Mix 20 Lb Logo
1,392 people viewed this question
Top St Gabriel Laboratories Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
Are you a St Gabriel Laboratories Garden Expert? Answer questions, earn points and help others
