Question about Kia Vehicle Parts & Accessories
My 2004 kia amanti will only make a loud clicking noise when i try to start it. it sounds like the starter is stuck.
Engine will not turn over
Posted by vincente dumanal... on
  • mike h
    mike h Jul 29, 2012
    sounds like the engine is seized... is the battery charged?
anderalex82
    New Friend:
  • 13 Answers
You have a bad starter from what you are describing. Did this just happen all of a sudden? Or has it been happening until the car died?
Posted on Jul 30, 2012
My car is a 2004 kia amanti, not a nissan sentra. the alternator and drivebelt has got nothing to do with engine not turning over. the battery was checked out at a shop and it is o.k.
Lots of possibilities for a no start condition. Do you hear any type of noise (such as clicking, etc) when trying to start the car? If not, recheck all connections and fuses under the hood as well as inside the car. Is this an auto or manual transmission? If its manual check the switch on the clutch. It its auto it could be the neutral safety switch.
Jul 26, 2012 | 2004 Kia Amanti
My 2004 kia amanti just stopped running while i was driving it.it made a wierd noise somewhere in the front before it died. i tried to start it back up but it only made a loud clicking noise. we tried
Sounds like a bad battery or alternator, or it could have thrown the drive belt off. Check too see that the belt is still on and then charge the battery and see if it starts. If it starts, run for a while and dies again with no crank, it is most likely an alternator.
Jul 26, 2012 | 2002 Nissan Sentra
My car will only go 30 mph when i try to give it gas. what is wrong ? it have 136.000 miles on it 2004 kia amanti 6 cyl. /
Sounds like you have fuel pump issues. May need to replace the fuel pump. Does the check engine or service engine soon lights come on? That or maybe injectors, or something alone the fuel system line. First check would be fuel pump.
Jan 08, 2011 | 2004 Kia Amanti
Starter?
I know it sounds daft, but get a mate to turn the engine over, touch the starter motor, thats the round thing on the bottom of the engine, sorry i that sounds patronising, tap it softly with a peice of wood or a light hammer, the solinod is stuck, that will release it. Don't be scared to give it a whack, but only when someone is turning the engine over or it won't work.
Oct 22, 2009 | 2004 Dodge Neon
01 kia optima stalled and wont start...starter just clicks
It seems the starter is playing up.First check if your battery is charged fully or try to jump start and see what happens.If the engine start then it's either you need a new battery or else you need a replacement alternator.Test using a voltmeter if the actual altenator is working.Finally the last option is the starter motor that needs changing or fixing...Hope this helps.
Jul 03, 2009 | 2004 Kia Sorento
Noise coming form reer wheel
if its a ticking check to see if there is a screw or other object stuck in tire. if not look in between tire and hubcap for a rock or pebble, alst check treads.
Jun 24, 2009 | 2004 Kia Amanti
2004 Kia Rio Won't Start Clicking Noise Battery is GOOD
My 2004 Kia Rio just started losing compression and died on me. I tried starting it and it only clicks. I checked the battery cables and they are not corroded and very tight. Could it be the battery or the alternator not charging the battery? there is no water in the oil and it's not the water pump.
Mar 12, 2009 | 2004 Kia Rio
Starter clicks rapidly, not cranking, no ignition
It almost sounds like you have a loose connection at the battery. If the connection is loose it can cause the starter to click as you have described. Also it could be the starter itself. If the starter is bad (locked up) it can make the clicking noise and not start the engine. If you can get to the starter, try to tap on it with a hammer while someone is trying to start the engine. I hope this helps.
Jan 03, 2009 | 2004 Pontiac Grand Prix
Vehicle Parts & Accessories Logo
126 people viewed this question
Top Kia Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Kardoc
Marvin
Marvin
Are you a Kia Vehicle Part and Accessory Expert? Answer questions, earn points and help others
