Question about U-Line 75R Refrigerator
I have a uline ref. model u-2175rs-00 has er code but is running
4 Suggested Answers
Anonymous
SOURCE:
Anonymous
SOURCE: U-Line 2175RS
The sound you are hearing is the open door alarm. Make sure your door is able to close completely. If you have installed panels make sure they are aligned properly on the door and not getting caught up on the cabinets beside the unit.
Posted on Feb 13, 2008
Rich Wright
  • 286 Answers
SOURCE: uline under the counter two drawer refrig seems to
Hi
Er means that somthing is wrong. It could be a temperature problem that caused it. Does it beep at all. That is a alarm for the door being open. You may need to check the magnet on the door and the reed switch on the wall. Upper left for the top drawer. and on the bottom is on the grill and door. Normally this is something I would ask for a tech to look at. But if you feel confident to try this I can get you into the program to see what its telling us. Now hold the up arrow and at the same time press and release the light bulb 3 times. Then release the up arrow last. If you did this right then you will have a 0 on the display. Yes, Then up arrow until you get to 3. Then press and release, It should give you a number. E# ? Let me know what this is. You may have a couple so write down all of them.
Now after you got the number then just push up arrow until you get to 99 then press and release the light bulb to go back to the refrigeration cycle.
E3= bottom drawer open to long
E10= Top drawer open
E1 = Thermistor #1 open
E5 = 10 degrees to warm E6 = 10 degrees too cold E7= Thermistor 2 E8=Thermistor 3 E9 =Thermistor 4 open thermistor 1 located top drawer Thermistor#2 I/M or evap if no icemaker
Thermistor3 is located in freezer or base if no freezer thermistor 4 is drain pan
Hope this helps
Posted on Jul 24, 2009
exploreris
  • 176 Answers
SOURCE: my uline keeps running and soda in cans freeze.
your thermostat is bloked or didn't see the reeal temperature, it must be replaced whit similar new one.
Posted on Feb 21, 2010
LG lfx31945 REFIGERATOR...FREEZER NOT COOLING. ER FF CODE
LG Help Library: Error Codes - Refrigerator ' LG U.S.A
www.lg.com > Home > Support > Product Help > Help Library
  1. Cached
  2. Similar
Feb 26, 2018 - FF Error Code. A FF error code indicates that the unit has detected an issue with the freezer fan. This can sometimes be caused by frost buildup. ... If you notice frost buildup along the walls of the freezer compartment, the leveling and door alignment of the refrigerator will need to be checked.
SOLVED: Error Code ER FF - Fixya
www.fixya.com/support/t121701-error_code_er_ff
  1. Cached
  2. Similar
Oct 18, 2006 - Error Code ER FF Our refrigerator is 1 year & 1 week old. A few days ago it started making a noise that sounded - LG LRBC22544 Bottom Freezer question. SOLVED: Error codes Er rF 10 posts 14 Nov 2013 Lg lfx31925st 00 code er ff 10 posts 21 Sep 2013 SOLVED: How Do You Repair An lg lfx31925st error ... 11 posts 16 Nov 2012 SOLVED: LG refrigerator lrsc26944tt error code ER FF 11 posts 25 Jan 2009 More results from www.fixya.com
FIXED LG refrigerator error code Er FF - ApplianceBlog
https://www.applianceblog.com/mainforums/.../8302-LG-refrigerator-error-code-Er-F...
  1. Cached
  2. Similar
Mar 31, 2007 - Hey guys, This LG has me stuck. I have run the smart board entirely through the diagnostic mode and it says everything is OK - hours later a code comes up "Er FF" Model: LRSC26922TT Serial: 407KRPV00464 I have had no luck finding any useful info on the web.... nothing but horror stories about LG. FIXED LG Refrigerator LFXS32726 - Error Code E rF 3 Aug 2016 LG LFX31925 drain iced up (ER FF code) - How to remove freezer ... 24 May 2016 FIXED LG LFX31925ST Giving error code ER RF 3 Sep 2013 Kenmore elite refrigerator error code er FF 3 Mar 2013 More results from www.applianceblog.com
LG REFRIGERATOR REPAIR. HOW TO REPLACE FREEZER FAN. FF ...
9k=? 4:42 https://www.youtube.com/watch?v=Yiifd2sTrZI
  1. Similar
Jan 3, 2013 - Uploaded by SOCALAPPLIANCE LG Refrigerator repair. FF error code / ee ff . Bad freezer fan. Bad evaporator fan. How to repair an LG ...
Mar 22, 2018 | LG Refrigerators
Need to replace circuit board, how do i?
take screws out pull old board out put new one in
May 24, 2014 | ULINE U-Line 2175BEVCS-00 2000 Series 24"...
My uline keeps running and soda in cans freeze. Thermostat setting is at lowest but I also tried midway. Model ULN-CO75FWH-00
Feb 21, 2010 | U-Line Uline Origins Series...
Error code er 55? I am not getting water into ice
There are several issues with this ref.
Ref. Lamp cover melting.
Department of energy rework.
Contact LG for service repairs are free.
Jan 04, 2010 | LG LFX25960ST Stainless Steel French Door...
My Uline ? Model U-217RS-O is 14 months old. The problem I have is the temp will not go below 38. What can I do?
Ok On the display hold the up arrow for 5 seconds then let go. It will tell you the temperature. Do you have and er at the display? Is the unit outside? What is the temperature(ambient) around the unit? If you hold the up and down arrows together for 5 seconds then release it will show you thermistor temperature for 2,3, and 4 You should only get 2 to give a temperature. 1=refrigerator temp and 2=evaporator temp.
Make sure the condenser is clean from dust.
Jun 28, 2009 | U-Line ?chelon 2175RB-00
U-Line 2175RS
Feb 03, 2008 | U-Line ?chelon 2175RB-00
U-Line 75R Refrigerator Logo
894 people viewed this question
Top U-Line Refrigerators Experts
Marvin
Marvin
ray gallant
brokenrubber
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
