Ok, I have tried everything, I have changed my .mod files to .vob, which i was told is compatible with home DVD players for TV. I have changed them to .avi. mpeg 1 and 2. All to no avail, none of my DVD players will recognise the videos i have burnt. Can anynoe give me a simple solution as to how to get my videos from my camera to the computer to a DVD so that it will play on TV. I mean you buy a camera, you get Power Producer/Director etc with it, but it then does not allow you to burn it to DVD for your own enjoyment, at the moment I am stuck on having my files on my computer and at minimum 2Gb per say 20 minutes footage, it eats up the memory pretty quick not to mention you can't enjoy the videos with anyone else unless you have a computer nearby? Can someone help.... PLEASE!!!!
SOURCE: BURN HOME VIDEO TO DVD
Assuming that your camera is not equipped to interface directly with your PC, here are the steps to take to get your videos from VHS to DVD:
- Purchase a video capture device.
A cursory websearch garnered once for $50.00 here:
ADS Tech Video Xpress
http://www.pcmag.com/article2/0,1759,1902901,00.asp
- After setting the device up, use the bundled software to convert the video file into DVD format and then burn to disc, using your favorite burnig software. Be sure that it is burning in the VIDEO_TS/AUDIO_TS format and not just copying the .avi to the DVD.
If you would like for me to elaborate on anyt of these instructions, please don't hesitate to contact me directly at [email protected]. Good luck and, again, let me know if there's anything else I can do. I think you'll be just fine though as this process is fairly straightforward...just time-consuming.
SOURCE: MOD file
The MOD file is just MPG format,
a simple MS-DOS command line instruction to rename your MOD files to MPG files (first copy your camcorder-harddisk files to PC-harddisk). I use to do the same!
Just execute the following command in the proper directory (or place this line in RENAME_MOD2MPG.BAT, and execute BAT file by doubleclick); the command assumes the JVC 3hexa-digit method of numbering:
ren MOV???.MOD MOV???.MPG
SOURCE: jvc power cinema NE for everio digital video camera, no sound on dvds??
I had a similar problem, I could play videos on my PC but they had no sounds.
I found a solution
In theory *.Mod Files contains mpeg format for the video and AC3 format for the sound.
In my case I was missing the codec fot AC3 format.
I downloaded one here:
http://www.free-codecs.com/download/ac3_filter.htm
And it worked
Sam
SOURCE: can't transfer videos from JVC GZ MG575AA to my windows XP
MOD Video Converter is an all-in-one program dealing with .MOD files.
1.You can transform the MOD files to AVI, WMV, or MPEG video forWindows Movie Maker, and other target video types also supported, suchas RMVB, RM, MOV, MP4, 3GP, FLV, SWF, VOB, DV, M4V, etc.
http://www.modvideoconverter.net/mod-to-windows-movie-maker.htm
SOURCE: Using .MOD Files In Adobe Premiere Pro CS3 solutions are flawed.
Many users had purchased HD digital cameras such as Panasonic SV AV100, Canon MOD Camcorders, JVC (MOD and TOD) and Panasonic (MOD only)and were frustrated by the uncommon .mod files, which can not be supported by general windows software. But they really wanted a way to play and edit MOD file on their PC, in this case, MOD Converter can be a good option.
Mod converter is a great application that helped HD camcorder users in particular because it can convert MOD to AVI, convert Mod to MPG, convert MOD to WMV,convert MOD to MPEG2, convert MOD to MP4 video, mod conversion in Windows Movie Maker, mod file converter which can then be used with Windows Movie Maker or other video editing applications(including Sony Vegas, Adobe Premiere Pro) for Windows.
Mod converter can be used as mod mp3 converter. By converting the MOD footage into other regular video and audio formats such as: MPEG, MPEG2, 3GP, 3G2, MP4, M4V, RM, RMVB, ASF, QT, TS, MKV, FLV, SWF, MP3, MP2, AAC, AC3, WAV, WMA, M4A, RA, RAM, etc, Mod video converter makes it easy to enjoy the MOD footage from your camcorder using iPod, iPhone, Apple TV, BlackBerry, GPhone, PSP, Zune, Creative Zen, iRivier and other MP4 players. With it, you can edit mod video, trim mod video, crop mod video easily, adjust mod video aspect ratio to 4:3 or 16:9.
Free download mod converter
