Question about Sharp AR-164 Copier
Sharp ar-164 - Displays "h4"
Hi our copy machine at our small office is not working. If you can help me be the one who saves the day I would appreciate it! On startup it just displays the error: "H4" (flashes an 'h' and then a '4', over and over). I have looked around online to no avail. Tried reset codes, none appear to be the correct ones. What is needed to be done with this machine?
Posted by Joe Michael on
vahidzz
    Habit-Forming:
  • 41 Answers
This error means:
heat roller abnormally low temperature.
for reset:
clear key --> interrupt key --> "0" key --> interrupt key --> 14 --> start key
Posted on Jul 26, 2012
5 Related Answers
Anonymous
  • 146 Answers
SOURCE: Sharp AR-M237 Error Code H4-21
-H4-21 means:Sub heater lamp abnormally low temperature detection. The setup temperature (about –25°C: Sim 43-1-1) is not reached within the specified time (about 32sec) from turning on the power ON SW. (When the temperature falls below 140°C in the standby mode.)
-Causes:
Sub heater thermistor defect
Sub heater lamp failure
Sub thermostat failure
Control PWB failure
-Check the sub heater lamp blinking with SIM 5-2-2.
When the lamp blinks normally: Check the thermistor and the harness. Check the MCU PWB thermistor input circuit.
When the lamp does not light: Check for disconnection of the heater lamp and thermostat. Check the interlock switch. Check the power PWB and the MCU PWB lamp control circuit.
Clear the display of self-diagnostics with SIM 14.
The H4 errors will not reset by themselves. You must enter service mode to reset this error even if the problem has been repaired. The reset process is outlined below (DO NOT USE ANY OTHER FUNCTIONS IN SERVICE MODE):
Press the following sequence: "#/P" "*" "C" "*"
Type in 1 4
Press start
hit 1 for yes
hit start
Unit should power off and the restart.
If the error code recurrs ther are other problems.
Posted on Jun 06, 2008
Anonymous
  • 62 Answers
SOURCE: Error code H4-01
This mean you have low temp. on heat lamp 2 program interput clear interrupt 14 print may clear this code. if not you can look at the fusing unit and reset thrmo breaker that may be pop off.
Posted on Jul 30, 2008
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: HELP, H4 ERROR
The fuser isn't heating up on time. You could try turning the copier off for 30 seconds and turing it back on again to see if it goes away.
If it doesn't happen, there is a part that has to be fixed on the fuser to correct the problem. Usually it is the thermistor.
Posted on Aug 17, 2008
Anonymous
  • 95 Answers
SOURCE: dispays h4 error
An H4 error code indicates trouble in the fusing section - a certain temperature has not been reached within a specified time. It could mean a dirty/bad thermistor or dirty/bad thermostat (both inside the fuser unit. Make sure both of these are clean and there is not debris/paper stuck inside the unit.
You can try resetting the code by : Get into SIM mode by pressing the following keys one after the other "#" "interupt" "C" "interupt" then enter 14 and the start key - confirm if requested then make sure the copier restarts.
Hope this helps.
Posted on Apr 18, 2009
Anonymous
  • 95 Answers
SOURCE: system error H4-00
H4 indicates a heating problem in the fuser. The roller never reached a specific temp. Make sure the fuser is free of any left over paper pieces (maybe from a paper jam). Check to make sure its clean.
Try reseting the the error in service mode.
To enter the test command mode, press the keys as
follows one after the other :
[#] key [*] key [C] key [*] key then enter 14 and press start/copy key. this clear error counter. make sure to restart copier afterwards.
Posted on May 20, 2009
In October 2010, install Office Professional Microsot Primewn. After use, it stopped working. A few days ago I burn leaves or applications such as Word, Excel and Power Point at all times remains...
Suggest OpenOffice instead.
1) Anything generated on a computer with OpenOffice, can be used on a computer with MS Office.
2) Anything generated on a computer with MS Office, can be used on a computer with OpenOffice.
3) There is no 'learning curve'. The user interface of OpenOffice looks VERY close to MS Office.
4) It is F-R-E-E
(Told MS Office to....um, well..........and have been using OpenOffice since. More than 3 years ago. Tired of MS Office 'parlor tricks', and losing saved documents, (Try 3 years of tax papers)
Am I proficient with using an office program? Nope. Admit it. I am a computer hardware geek.
Still stand by OpenOffice though, because those who ARE proficient, say it is GOOD.
Just my 2cents, John.
Regards,
joecoolvette
1) http://www.openoffice.org/
2) Screenshots,
http://www.openoffice.org/product/index.html
Click, one at a time on the blue;
Writer
Calc
Impress
Draw
Base
Math
Nov 12, 2012 | Dell Inspiron 1525 (dndwpa3_6) Intel Core...
Do your Acer laptops come with a Word software package? My sister is unable to find a software package on her machine. Please help, even if the answer is downloading something from the internet. Some...
New laptops come with a trail version of Office, good for 90 days.
Instaed of spending any money on Microsoft Office, download Open Office, which is fully compatible with Office
Download it from here :
http://download.openoffice.org/
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Aug 02, 2011 | Acer Computers & Internet
I can't open an excel file with my laptop
Hi simple,
I see that you are having issue opening an excel file with your Laptop what error do you get and what version of Office are you using?
If the Excel file that you are trying to open was save using a 2007 version or 2010 version and was not save as 2003 readable file then that will really be a problem, it is either you get the latest version of Office or you can go back from where you got the file and save it in a format that will be compatible to a lower version of Office.
When saving you just click on File then click Save as it will give you the options on how you want the file to be saved as, you just selct the format Excel 97-2003 Workbook, this should make it work with the latest version of excel and as well as the oldest versions of excel.
I hope that this help.
Have a nice day,
mvincentc
Jun 07, 2011 | Microsoft Computers & Internet
Window vista is asking for product key which i dont remember please help?
Hi, Yes you can find the key, using a small free program
Get it here
http://www.magicaljellybean.com/keyfinder.shtml
The Magical Jelly Bean Keyfinder is a freeware utility that retrieves your
Product Key (cd key) used to install windows from your registry. It has the
options to copy the key to clipboard, save it to a text file, or print it
for safekeeping. It works on Windows 95, 98, ME, NT4, 2000, XP, Server 2003,
Windows Vista, Office 97, Office XP, and Office 2003.
Please rate this solution. Regards.
Nov 09, 2010 | Computers & Internet
What is the 25 characters product key in ms office home and student 2007
The 25 character product key is the licence key to activate MS Office so that you can utilize all the features of Ms Office. It is the one you are paying for. If in case the installation disc is damaged or lost, that would be fine if you saved teh copy of the product key on a safe place. You can log on to Microsoft to get more inforation on how to get a valid product key.
Thank you for using Fixya. You high recommendatino is higly appreciated.
Sep 19, 2010 | Computers & Internet
This is the about page of Microsoft Office 2007 (Microsoft® Office Word 2007 (12.0.6212.1000) SP1 MSO (12.0.6213.1000)) I?ve used your codes and countless others and none seem to work. I am working...
If you installed Office 2007, it configures itself as the program to be used to "open" any 'DOC' files.
If Word 2000 is still installed, start it.
Then, use 'File' and 'Open' to select & read your file from your USB flash-drive.
Apr 05, 2010 | Microsoft Office Professional 2007 Full...
Sharp AR-164 Copier Logo
186 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
