Question about Bravetti EP4305FS Deep Fryer
Magnetic plug won't stay pluged in
We have a Bravetti deep fryer with the magnetic plug, and I find it to be not strong enough magnet to hold it in place to keep it powered up . I hate this type of plug it won't even suport the weight of the cord, it is a piece of junk !!!!!!!!!!!!!!!! I realize it is for safty reasons that if someone trips or pulls the fryer off its upright position that the cord disconects power. But the magnet is just too easy to disconect from the fryer
Posted by Gordrich on
Russ Hill
  • 4,057 Answers
Double sided tape thin type that should hole in place clean both sides, if some one trips it still comes out easy.
Posted on Jun 28, 2017
1 Related Answer
Jeffrey Robertson
  • 43 Answers
SOURCE: Who sells a power cord that fits a NEW Bravetti deep fat fryer?
New cords can be bought from
Euro-pro.com
Posted on Jul 04, 2009
I've used the fryer twice, cleaned it last night, now it won't power up. Has the magnetic cord. Seems like everything is just how I had it when it worked last night.
twiddle and fiddle with the magnetic connector until it works. These new safety devices burn out or just plain don't work too often. It takes a little practice to get that magnet plug in the right place. 25334073-eqln1e0r5dvuapuxoxy4lmrd-1-0.jpg
Whatever happened to the old school ones that worked for fifty years? They live on at yard sales everywhere....
Dec 23, 2014 | Kitchen Appliances - Others
Put a new valve in a imperial fryer pilot lights and stays lit but when i turn the t-stat on it shuts off
The reason is the pilot generator will hold the safety magnet but it won't operate the solenoid.
It is old and weak.Ain't putting out enough power to operate the solenoid. Get a new generator
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 16, 2011 | Imperial IFS40 Deep Fryer
Need a plug in cord for a bravetti platinium pro fryer 2 prong
Where can i buy a magnetic break-away cord for a Bravetti F1075H Deep Fryer
May 28, 2010 | Bravetti F1075H Deep Fryer
Danger of Physical Harm
It sounds like a water pocket in something opened up. Food that is already cooking won't erupt grease unless there is a sudden addition of moisture. The unit should be safe to use. Just make sure you wick the moisture off things before you fry them. It would be shameful to stop eating fried foods, they're the best tasting type of food.
Jan 31, 2009 | Bravetti F1075H Deep Fryer
Magnetic breakaway power cord for rival deep fryer
Power cord can be found on amazon (original), click here and take a look: Finally charging for our multi device world. I hope this was helpful. Cheers
Aug 21, 2008 | Rival RCF25 Deep Fryer
No electrical power
j'ai une friteuse bravetti avec prise maquétiquequi ne tiens pas elle est toujours tombé et je commence a en avoir peurquand elle réusi a atteindre sa température elle fait un un bruit de dilatation a faire sursauter.
France
Jul 27, 2008 | Bravetti F1075H Deep Fryer
Bravetti Deep Fryer Model F1053B Not getting Power anymore
Hey guys I fixed my problem...yay. All I did was to push a red button which I beleive is a resset button on the back of the on/off button part. It ain't visible but if you look in the holes of the screws that hold this part together (they are far down in the hole) one of them hides a small red button. Push it down with a toothpick or anything small enough to fit the hole and you're done. Plug it back and it works.
Apr 13, 2008 | Bravetti EP4305FS Deep Fryer
Presto Model 0692001
Same her but I found this info,
Presto multi cooker magnetic cord 09984
Replacement magnetic cord fits Presto Kitchen Kettle multi cookers from model numbers 0600001, 0600002, 0600003, 0600004, 0600007, 0600009, 0600010, 0600101, 0600110, 0600203, 0600305, 0600306, 0600308. Original part number 09984.look on the bottom of the fryer not on the plug to find these numbers.
Nov 13, 2007 | GE 168997 Deep Fryer
WOlfgang Puck Deep Fryer 1500 watts power cord
Hi - The 1700 watt fryer uses a magnetic release cord set type TA 35 P. If your unit says "use only with TA HSING CORD SET TYPE TA 35P, It should work.
Oct 22, 2007 | Wolfgang Puck Bistro 1700 Deep Fryer
Bravetti EP4305FS Deep Fryer Logo
Top Bravetti Kitchen Appliances - Others Experts
Mike
ADMIN Canada
ADMIN Canada
ray gallant
Are you a Bravetti Kitchen Appliances - Other Expert? Answer questions, earn points and help others
