SOURCE: Amana Dryer model # LEA60AW. Dryer runs but no heat.
check the heating element and the high limit fuse
SOURCE: my amana dryer took two cycles to dry cloths
check the belt! also check the drum rear bushing after you remove the back and remove the top! then take the 2 inner front screws lose from the front cover and take the 2 bottom screws out and look to see if the drum/tub guides are worn out
SOURCE: amana dryer NED7200TW quit heating, it appears
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
SOURCE: My dryer is an Amana #NED7200TW and I got a code
HE shows up because there is no heat . Check the fuses in the panel and the heater itself. Also could be the sensor is not working to tell the control to turn the heater on.
SOURCE: I have replaced the thermistor
Hello, welcome to FixYa.
I'll start by saying your post indicates it is a Amana dryer, (as you may or may not know this model is built by Samsung) and it is displaying a e5 error (actually looks like a e5 error, but it is indeed t5 but that's because of the digital display)...it is actually a "temperature sensor" error, hence the "ts".
As described in the service manual from Maytag...
"tS" Dryer Thermistor Short Sensed - The Thermistor resistance is very low.
Check for:
Clogged lint screen. (remove and wash under hot water & mild soap...a old toothbrush works well for scrubbing)
Restricted vent system.
Check Thermistor resistance...10000 ohms @ 77°F/25°C
If you've replaced the thermistor already, that leaves either poor air flow due to clogged lint screen or clogged exhaust somewhere else along the line. Here's what I would suggest you try. Remove the lint filter (clean it as mentioned above) and unfasten the vent from the back/side of the dryer, whatever the case on your machine. Run it through a cycle without a load and post back with the results.
I can send you the service manual if you think it may help you move forward,(It says Maytag, but those are Amana/Samsung as well) but you'd need to provide an email address for me to attach it to. It is a "pdf" and 9.9mb in size.
I'll watch for your reply.
Regards,
Macmarkus :)
I have the same problem. The flashing C's and it shuts off and comes on over and over before the clothes are dry. What can I do?
No No No ... Nothing wrong with machine. It just went into "wrinkle Prevent" option. It can be turned off. Otherwise it could run up to 95 minute extra
