Originally Posted by MIRYALA SRINIVAS hwk Update server has crashed,ODIA TEAM is working to fix the issue ASAP.
So dont update your box.
We inform you when server is working fine
Br.
Vijendra Saini.dear sir,
i have format my pc then i need to install what should i do????????
Upgrade log:
---------- HWK Update Client v 2.0.8.0 ----------
---------- HWK upgrade started:9/8/2009 8:19:09 PM ----------
-- Target Id : 62 CF 1 10
-- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003.
-- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007.
-- UFSx S/N : 71327
-- Features : 00000001
-- Licence 5 : True
-- UFSx Vendor: TORNADO
-- HWK ID : A1.04-PRO1-7ACEA977416000C9
-- HWK Status : 1, DL: 0
Locating HWK Upgrade server...
HWK Upgrade server found!
Preparing connection to server...
Connecting to HWKUpgrade server...
Server connection successfully established.
Authenticating on server...
Authentication stage error: Error: Server returned unrecognized reply
Successfully established. Authenticating on server... Authentication stage error: Server reported error:No more upgrade logs. Please contact your reseller.
I am currently using hwk update client v 2.2.0.0 and I am getting Authentication stage error: Error: Server returned unrecognized reply.
SOURCE: Using 1000SW,
When you get a 'cant connect to configuration server', dont worry about it, thats 2wire's configuration server. If you have a 1000sw, then you've been a customer for a long time and have been registered for years and dont need the configuration server. Both you and the 2wire have been configured for years. The 2wire is trying to reach the configuration server because you set it up again, im thinking you moved, changed phone lines, or changed service.
The 2wire configuration server is to set people's 2wire's up for the first time only, and even then it doesnt matter unless you call technical support, and then they can still help you by getting the serial number off the device when that happens years later.
spin
SOURCE: cannot connect to internet on my laptop with linksis router
do you check the interface up.
do you check the protocol up .
do you have a signale untell your router before connect it
[email protected]
