Question about Hayward Pro Series 18" Above Ground Pool Sand Filter System with Pump
SOURCE: I recieved a Sp 0711-A13 Hayward Pro Series sand
you can go to http://www.haywardnet.com and get all the info you need. You can download a manual there. Go to products, and then above or inground and then on literature&manuals
Posted on Jul 24, 2010
SOURCE: is the Hayward s210 pro series 21" top mount above
Thank you for posting your question here on Fixya.com. If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
32' round by how deep? Flow rate is how you size a filter so with total gallons you can calculate how many per minute will add up to the whole pool being turned over is 6-8 hours. The pump and filter are then sized for that required flow...Assuming the pool is an above ground ~4' average depth then total gallons would be about 24,000 gallons. For an 8 hour turnover you would need about 50 gallons per minute. The 210T, T for top mount, is designed to handle up to 44 gallons per minute and turn over a 21,000 gallon pool in 8 hours or a 26,000 gallon pool in 10.
What that basically means is that using a 210 on a pool 32 x 4 would be pushing it. It will work but you will end up backwashing more frequently which raises the overall cost of running the pool. If it is not to late a 24" filter would be better; especially if you have periods of time in your pool season where heavy amounts of debris such as pollen get into the water. A 21" filter won't handle any over a normal filtration load.
Posted on Apr 29, 2011
SOURCE: I have a 15x24x52 above ground pool. I have been
Hi, Your filter maybe clogging up. Clean it out and/or replace it.
Posted on Jun 17, 2011
Jul 18, 2011 | Hayward SAND FILTER, PRO SERIES
Jun 17, 2011 | Hayward Pro Series 24 Inch In Ground Pool...
Apr 28, 2011 | Hayward Pro Series 21" Above Ground Pool...
Jul 02, 2010 | Hayward Pro Series 18" Above Ground Pool...
Jun 19, 2010 | Hayward Pro Series 21" Above Ground Pool...
Feb 11, 2010 | Hayward Pro Series 18" Above Ground Pool...
Aug 12, 2009 | Hayward Pro Series 18" Above Ground Pool...
Jul 24, 2009 | Hayward Pro Series 18" Above Ground Pool...
43 people viewed this question
