Question about Yahoo Messenger
I want to delete contacts from my yahoo but i use ipad..how i will do it
I use ipad but i can not delete some contact to my yahoo messenger
Posted by Maylien saberon on
5 Related Answers
Anonymous
SOURCE: Yahoo Messenger List/Address Book
I have since found out that you have to actually go into your contacts under yahoo mail and delete them from that list, then it deletes them from your messenger. Found this solution on another website. Hope this helps anyone else who is having that problem.
Posted on Feb 27, 2009
Anonymous
SOURCE: friends' yahoo messenger ID blocked.Can't add it to my msgr list!
I have used Zak's nobuddy before - it has been updated to work with yahoo's newest protocols.
Test: (A) I have 2 yahoo ID's - I added each to the other:
(B) I use Yahoo Messenger version 9.0.0.2162
(C) I was invisible mode at all times on each ID
1 I then got this zak nobuddy to remove one from the other:
2 It worked (although it left no message - I was simply gone).
3 I then performed the normal add request - this too worked fine and I was added again as soon as ID2 accepted.
You say it's blocked from your contact list:
I would check from messengers menu bar
messenger/ preferences/ ignore list and see if your friends ID is in there.
Posted on Sep 27, 2009
Anonymous
  • 10 Answers
SOURCE: what justin bieber's yahoo messenger?
find the id in ym fast
Posted on May 29, 2010
Ali Shahzad
  • 53 Answers
SOURCE: why cant i add contacts in yahoo messenger
Click the + button in the contact option, and you will get to know how to add the contact, otherwise add your contact directly from your YAHOO MAIL. http://mail.yahoo.com
Posted on Jul 28, 2011
Elboy
SOURCE: your request to add a
Google it and no satisfactory answer, same problem with us and gives us headache.
Posted on Aug 03, 2011
How do i delete contacts in the new yahoo messenger
  1. Go to Yahoo Mail. Open any web browser and go to the Yahoo Mail page.
  2. Sign into Yahoo. Enter your Yahoo ID and password on the fields provided then click the "Sign In" button. ...
  3. Access Yahoo Messenger. ...
  4. Sign into Yahoo Messenger. ...
  5. View the contacts list. ...
  6. Delete a contact.
Feb 04, 2018 | Yahoo Computers & Internet
How do I delete a contact from yahoo mail contacts list .
To delete a contact from your address book:
  1. In the Address Book, select a contact, then select Delete from the Contacts menu or select Delete from the right-click menu.
  2. In the Delete From Address Book window, confirm the deletion by clicking the Yes button.
    To delete one or more contacts from your Messenger List:
  1. In your Messenger List, select one or more contact names (hold down the Ctrl key while selecting multiple names), then select Delete from the Contacts menu or select Delete from the right-click menu.
    The Delete Contact window opens.
  2. Confirm the deletion by clicking the Yes button.
    Tip: Check Delete From Address Book, too to remove this contact from your Yahoo! Contacts
Oct 08, 2011 | Yahoo Mail
I cant delete contacts from my list..i have tried with right click it doesnt work.i need help plz
Right clicking won't work. To delete contact on your Yahoo! Messenger, hover your mouse over the contact you want to delete, then click the drop-down menu and then click "delete".
Thanks for using Fixya!
You can rate my answer if it helped you.
Sep 28, 2011 | Yahoo Messenger
Delete contacts from yahoo messenger
Open Yahoo!Messenger, login and on the lists of contacts, right click one of the contacts, select "Delete", the selected contact will be deleted. If you wish to delete multiple contacts, hold down "Ctrl" on the keyboard while you click the names in the contact lists. Once the contacts are selected, right click and select "Delete" to delete them.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Apr 18, 2011 | Yahoo Messenger
Mhow to delete someone on your messenger list
you may wanna try this:
How to Delete a Contact Text Size: small A normal A large A ID: DOC263
To delete someone from your Messenger List:
  1. Click the contact's name while pressing the Control key to highlight the contact. (You can also right-click on the contact's name.)
  2. Select Delete.
  3. Click the Delete confirmation.
To delete someone using the Contacts menu:
  1. Click the contact's name in your Messenger List.
  2. Click the Contacts menu and select Delete.
if this helps pls rate me thanks
Mar 22, 2011 | Yahoo Messenger
I cannot delete several of my messenger contacts even though i deleted from my mail address book. when I try to delete them, I get the following error message: The last Address Book operation did not...
Seems Error Code 40402 pops up when trying to remove them while in your Yahoo Instant Messenger list first.
Glitches and Updates!!! Here's a work around though.
You will need to go to your Yahoo Email Account and delete the contact's name there first.
1. Click Contacts from your Email page to open your list of Contacts.
2. Go to the one you wish to remove and check the box next to it.
3. Go to the top of the list and click the Delete button.
Go to Yahoo Instant Messenger, right click the name and select Delete from the drop down menu.
Nov 13, 2009 | Yahoo Messenger
If I delete a yahoo mesanger contact, does it automatically delete my icon from their list to let them know that they have been deleted?
No, because when you add a contact from yahoo messenger, it acts like a phone book, so if you delete one of your contacts the only thing that will disappear is that contact information that you have deleted. They will not know when you have deleted them. i have tried and tested it.
Hope i can help you out with this
Thank you :)
Aug 08, 2009 | Yahoo Messenger
Yahoo messenger error code -40402
[Solution # 1]
You will need to go to your Yahoo! Email Account and delete the contact's name there first.
1. Click Contacts from in the toolboxt to open.
2. Go to the contact you wish to remove and click the box next to it.
Go to Messenger. When your list of Contacts opens, right click next to the name you wish to remove and select Delete from the drop down menu. The contact will be removed here also.
Error Code 40402 pops up when trying to remove a name while in your Yahoo Instant Messenger list first.
[Solution # 2]
Quit the program, then delete the contents of the “Cache”-folder located here:
c:/program files/Yahoo/Messenger/Cache
That usually solves a lot of problems, that occur all of a sudden. Try that and see if it works
[Solution # 3]
most probably a registry error - if you do not have a registry cleaner try downloading the free version of ccleaner from filehippo
once its downloaded select 'registry' from toolbar on left hand side and run 'scan for issues' followed by 'fix selected errors' if errors are detected
use microsoft 'one care' for further check
Hope they could help you
Good luck
Mar 23, 2009 | Yahoo Messenger
My yahoo messenger..
you can easily just download and install any version of yahoo messenger you want on top of the one that you already have and it will over write it without any trouble.
Oct 30, 2008 | Yahoo Messenger
Deletion of contacts lists on both Yahoo email and Messenger...
sorry once you delete your email contact lists, it's forever deleted.
Oct 27, 2008 | Yahoo Mail
Yahoo Messenger Logo
359 people viewed this question
Top Yahoo Apps Experts
Gustavo Ortiz
Gustavo Ortiz
Marvin
Marvin
Harrie
Are you a Yahoo App Expert? Answer questions, earn points and help others
