I have a Hotpoint Washing Machine WMA20/22 and it spins slow but does not go into a fast spin. Plse help.
Most likely something stuck in the pump. Remove front panel and hose that goes into pump. usually you will see the object. if not remove pump and look inside.
SOURCE: does not spin and rinse properly
Sounds like motor is not coming up to spin speed. May be overheating, in which case you would need a new motor.
SOURCE: My washing machine has stopped spinning.
it sound like your belt has come off if not wait till its dark put it on spin turn the light off if you can see flashes coming from under the machine it your brushes that need replaced on the motor
SOURCE: Noisy spin on hotpoint aquarius WF530 6kg washing machine. Suspect bearing how do I replace them.
If you spin the drum by hand, and it is niosy and rumbling then the main drum bearings have failed.
If under 5 years old, then you should be able to get it repaired under Hotpoint 5 year guarantee, You just pay for labour and call out, cheapest option, it is not really a D.I.Y job, as it is quite involved, and entails a lot of work.
Please rate my advice.
Thanks.
SOURCE: I have a Hotpoint WF540 washing machine. When it
Sounds like drum bearings most cases you need to buy half drum with bearings fitted if your very good at diy no problem if not call engineer.1st check concrete weights are not loose top and bottom.............you can buy parts @ espares.co.uk this will give you idea of cost which maybe quite high.
